| Home > Help Needed / General Tech Chat > Gearbox help | |||||||
![]() 214 Posts Member #: 1574 Senior Member Malta |
8th Jan, 2008 at 08:22:10am
I'm in the process of completing a 1275 gearbox rebuild and have found a problem with the casing which means it is probably U/S. The only other engine I have to hand is a 998cc. Does anyone know if the casings are compatible/interchangeable?
8th Jan, 2008 at 09:11:32am
8th Jan, 2008 at 09:15:58am
Bl**dy hell - something else I need to be sure of then. The case looks roughly the same attached to the block. Is anyone able to tell me the difference between A and A+.?
8th Jan, 2008 at 09:32:10am
8th Jan, 2008 at 10:26:19am
Thanks Bat, its just the casing I want to know about as all the internals are being replaced. To be clear I have a u/s 1275 gearbox case and a 998 gearbox case (unstripped and attached to a 998 block) and I just need to know if it is worth removing to use on the 1275 engine or if it will not fit for any reason.
8th Jan, 2008 at 10:31:32am
8th Jan, 2008 at 10:51:53am
Sorry if I sound like an idiot but I am a DIY mechanic and this is my hobby and first full vehicle rebuild. I have read some posts about differences in the gearboxes and it seems that the actual 998cc gearbox casing is compatible (although there are comments about mechinal component differnces). I intend to use all the components from the original gearbox (most of which are new) but the casing which is damaged will need to be junked. I just wanted to know if the casings are compatible and therefore it is worth the effort of removing and stripping the 998 box.
8th Jan, 2008 at 11:59:26am
Edited by Bat on 8th Jan, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
8th Jan, 2008 at 12:14:31pm
What's U/S? Undersize? On 13th Jul, 2012 Ben H said:
8th Jan, 2008 at 12:17:16pm
8th Jan, 2008 at 12:17:42pm
What are the casting numbers on each of them, they don't have to be the same, but knowing them both will say which bits can/can't be interchanged. Schrödinger's cat - so which one am I ??? |
8th Jan, 2008 at 12:37:17pm
Take the flywheel and transfer gear housing off your 998. Remove the standard drop gears from the 998. Take the drop gears you were going to use in the 1275 and try the idler (middle one) in the bearing of the 998 gearbox. If it fits then the gearbox casing is compatible and will be fine for rebuilding your box internals into.
8th Jan, 2008 at 05:25:25pm
U/S = unservicable yes!! Thanks to both Tom and Gav - I guess I'll take the 998cc box off and try it as Tom suggests I was just trying to save some effort of stripping the 998 if it was certain to be no good. If there is a chance I'll give it a go as late gaeaboxes are not as available out here as the earlier ones. Someone told me you can spot an A+ engine simply by looking at the dipstick receptacle. The earlier ones have a step or insert tube and the A+ is shorter. Is that right?
8th Jan, 2008 at 05:34:37pm
8th Jan, 2008 at 05:40:43pm
Understood Gav. The box is def not an A+ so its seems like a trip to the breakers at the weekend. I've just got the flywheel off (pre verto clutch) so I'll try offering up the new drop gears later anyway... just in case!! Thanks.
8th Jan, 2008 at 06:05:43pm
There might be no need to strip anything (to know the answer) if you post the two gearbox casting numbers, ie,
8th Jan, 2008 at 08:19:42pm
redwing . john, you have the timkin SC idler dont you
Edited by BENROSS on 8th Jan, 2008.
11th Jan, 2008 at 10:00:57am
I'll get the casting numbers over the weekend and take a pictire of the offending bit of the gearbox. It looks as if it has been rebuilt before Steve and not too well. A component mounting hole has been ovalled.
11th Jan, 2008 at 06:21:47pm
we will sort you out john
14th Jan, 2008 at 12:35:33pm
All seems sorted now guys I found an A+ box at the breakers - thankyou all for your help. Thanks Steve for the PM info.
