Home > Help Needed / General Tech Chat > OT black smoke focus tdci
OT gents, focus tdci black smoke under boost, power is down, engine warning light intermitent, then sometimes stays on ?
the engine oil some months ago was over filled by a bufoon! at a local garage then the problems started, this nutter has now been given his bladders
the motors done 29k only
approx 1 liter over fill
the oil was droped to levell and problem was gone, for a few weeks.
its now reappered and same fault as above
any advice please! gents :) ....EGR VALVE fault ? seems to crop up ?
have you driven it hardish recently?, have you checked the boost pipes? does it have a FAP on it like the peugeots? have you checked oil in the turbo//intercooler? there is normally a bit but if it is excessive. is it getting on boost properly?
paul.
turbo hogster
Member #: 178
stowmaket suffolk
could be a sensor fault, like the air mass meter just after the air filter these are favorites, some times they need a clean, but have the fault codes checked this should lead you in the right direction
Mass air meter would be my guess too. But get the fault codes read it should be able to tell you itself what is the matter.
Richie
Member #: 628
as per Tom, Steve the engines are volvo units not ford, if you look on the water washer cap, infact most components, they are all volvo *wink* thats why the new focus's strike a resemblance to the new S40's :)
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
Carl
Member #: 95
liverpool-on-sea
is this any help
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=9230
Richie
Member #: 628
how fooking typical of this forum, such a random problem with a non a series diesel no less, and some fooker has laready had similar and a full tech fix it thread psml !!! classic only on TM !
to hijack this thread, iam after a nice economical deisel estate summit like a focus.
and of course at rock bottom price too
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
Richie ive been looking at a Diesel bus for pulling the mini to shows and you can pick a nice Escort Estate TDI T&T for around £500!
Escort TD's slow as fook, my granny can run faster.
Look for Xsara HDI, getting cheap now.
My money is on the EGR valve *wink*
thanks gents, superb carl
jimster realy whent to town with his indepth info on fault codes
Did the fault codes help you? Saves you buying a tool to read the codes.
i have to have a look later jim.
what was the black smoking problem anyway ?
thanks buddy
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
hmmm...
The diesel engine in the mk1 Focus us a Ford lump through and through - its actually a development of the original 1.6 push rod diesel from the early 80s, thats been endless updated.
In the mk2 lump it is a either the old 1.8 or a varity of PSA engines (DW4, DW10 etc) lump as Ford are still using PSA as a design partner in the same way BMW are with the new MINI engines.
The only engines that are shared with volvo are the 5 cylinder lumps (eg Focus ST).
Not being funny or trying to piss you off - just adding my 2p worth!
Alex
AlexF
The Ford 1.6 Diesel engines found in mk III
Escorts from '84 onwards were ohc, part gear part belt driven *wink*
Still think it's the EGR valve though *wink*
Richie
Member #: 628
Alex
hehehe please dont make me photo the engine bay on me patrol car :) everything is stamped Volvo.
the pandas are 1600 tdci jobbies turbo mounted at the front.
unless we have some sort of deal with them or summit.
Edited by Richie on 18th Jan, 2008.
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
Richie
Member #: 628
and your very welcome to ure 2pence bro *wink*
you do know that ford own volvo though dont you ?
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
When I worked for Ford's Diesel Research and Development Centre in Dunton they did own Volvo. So I believe they still do lol
Alex
AlexF
