| Home > Help Needed / General Tech Chat > turbo carb setup | |||||||
48 Posts Member #: 2111 Member colchester essex |
20th Jan, 2008 at 04:21:48pm
hiya all
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
20th Jan, 2008 at 04:23:22pm
the regulator must be fitted and you need an elctric fuel pump
20th Jan, 2008 at 04:30:55pm
Electrical pump has been fitted, fuel to carb ok, but NOT throught it..
20th Jan, 2008 at 04:31:07pm
there are various hifs, varios furl regulators, and various fuel pumps
20th Jan, 2008 at 04:33:44pm
20th Jan, 2008 at 04:34:46pm
You need to plumb in the proper fuel regulator and return to tank. Until you do this any amount of changes to the carb is a waste of time.
20th Jan, 2008 at 04:34:59pm
What do you mean "NOT through it" ? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Jan, 2008 at 04:35:07pm
Is it easy to convert the HIF44 and if so what do I need..
20th Jan, 2008 at 04:35:14pm
20th Jan, 2008 at 04:36:34pm
Fuel reaching chamber but not jetting when turning over !
20th Jan, 2008 at 04:36:41pm
20th Jan, 2008 at 04:37:35pm
20th Jan, 2008 at 04:38:10pm
Stop pressing refresh after you have posted - it causes a double post. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Jan, 2008 at 04:38:17pm
what is the differnt between an HIF44 Carb and a turbo carb, if so any pics
20th Jan, 2008 at 04:41:43pm
do a search, this has been covered loads of times "Turbo's make torque, and torque makes fun"
20th Jan, 2008 at 04:42:10pm
Do a search, this has been discussed at length with pictures.
20th Jan, 2008 at 04:44:16pm
We have been searching most of the afternoon, with no joy.
20th Jan, 2008 at 04:54:20pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2878
On 19th Jan, 2010 wil_h said:
20th Jan, 2008 at 04:54:31pm
dose any body have any links plaese would help me out in a big way thanks
20th Jan, 2008 at 07:38:42pm
20th Jan, 2008 at 07:58:24pm
the turbo carb has a groove in the aliminium top bit just under the black plastic screw on the very top
20th Jan, 2008 at 08:33:18pm
If you have fuel in the float bowl then to just start the car you can forget about the fuel supply. With the float bowl full and no fuel coming out of the jet I can only think that there is either a blockage between the float bowel and jet or the needle you have is too fat and blocking the jet.
http://www.twin-turbo.co.uk
