Home > Help Needed / General Tech Chat > piper 285 cam specs???
clubminiflip
Member #: 54
nr coventry
after stripping my 1100 engine it has a piper 285 cam anyone know the specs of them, mines been used with a duplex timing chan on the standard timing dots
also i've found a kent 256 cam i forgot i had *surprised*D well happy but i dont know the spec of that either, anyonehave experiance of driving with either cam as i've not drivin with either
I've got a piper 285 in my 1380, lovely cam, loads of curly whirlys and bananas too :)
However it says in the bible best not to use in anything below 1275cc....
I put a 285 in a small bore once and it was rubbish. thw 256 is a good turbo cam.
see here http://www.kentcams.com/ stick 256 in the search and hey-presto you'll get the spec.
T3Tone
Member #: 252
Sunny suffolk
I would use a mild cam for a turbo, i use the kent 266 in a 1380 and its seems great so would also recommend the 256. Take advantage of the turbo set-up and have a nice tick over and smooth off boost driving, they still make the power:)
-MINI CLUBMAN 1380 TURBO-
