Home > Technical Chat > Has anybody fitted a Ford seira trigger wheel to a mini pulley How???
ROB1N
Member #: 664
South Wales (chepstow)
I have one and wondering how to attach it ,any ideas would be great cheers Rob
Edited by ROB1N on 3rd Mar, 2008.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I have put these on a few minis. Basically w ejust turned down a pulley to the correct size and then slipped it on with a bit of glue. On the TT it has some tabs welded to the pulley to keep it on. Both road cars are just push fitted though.
Looks a bit like this:
http://www.twin-turbo.co.uk
evolotion
Member #: 83
Glasgow, Scotland
where do you get those particular toothed wheels from? i salvaged one from an old sierra but there getting rare in the scrappies..
Denis O'Brien.
ROB1N
Member #: 664
have you any side pics the pulley when its machined is it fitted on the inner part of the pulley ?
i bolted mine onto the front of the pulley with 4 little bolts . ill find a pic ..
Edited by robert on 4th Mar, 2008.
ROB1N
Member #: 664
Does it work ok and what size bolts did you use off the top of your head
Edited by ROB1N on 5th Mar, 2008.
um....anyone translate that for me ,and put in the punctuation ?lol
On 4th Mar, 2008 ROB1N said:
Does it work ok bolted on? What size bolts did you use, off the top of your head
This any good Robert. *wink*
thanks matt , yes it does work ok , the bolts i think were 2 or 4 ba ,and a bit of loctite found its way in there too.
BA...you old boot! *laughing*
M5-M6 is probably easier to get hold of, especially with regards to taps.
been watching that snickers advert to much ''stop your jibba jabba fool'
classic prose. *laughing*
ROB1N
Member #: 664
bloody laptop has different key layout to my wifes laptop, i can type honest...?
ROB1N
Member #: 664
Managed to get the use of a lathe this morning and turned down my pulley .first time in ten years that ive used a lathe but it was a sucess ,will be fabing up a holder for the crank sensor tommorow hopefully
efully
Edited by ROB1N on 8th Mar, 2008.
Top job *wink*
ROB1N
Member #: 664
cheers
rhino-force
Member #: 2000
northampton
Great! do me one to.
Please
rhino-force
Member #: 2000
northampton
Please
ROB1N
Member #: 664
Here's it is painted
And heres the crank sensor holder i knocked up this morning its a bit rough but there we go ,it works though.
looks good enough to me *happy* what did you use to hold the trigger wheel to the pully in the end?
i was thinking a possible interference fit would work well, similar how ring gears used to be held on i believe or am i making that up?
ROB1N
Member #: 664
Yep the ring-gear method works well, once i machined the standard pulley and then i lightly trued up the trigger wheel .
you could use a grub screw to fix the outer ring to the damper, then you can loosen it and make minute adjustment to get the sensor exactly 90 btmtatdc (before the missing tooth at top dead centre)
do it like adjustable cam pulleys. a very good idea.
Sir Yun
Member #: 1592
Smart Guy!
will the quite heavy trigger wheel affect the damping characteristics? ( will it still work properly).
i'm looking on fitting one for a MJLite JR in a NA ( high-isch rpm) application.
edit:
This country has reached the point that no cvh fords are to be found.. mostly duratec stuff these days.
machining, 30 quid for a trigger wheel...
Sod it i'm buying a ready made one..
Edited by Sir Yun on 7th Apr, 2008.
