Home > Help Needed / General Tech Chat > relocating wiper motor
i was thinking of giving this a go this weekend to see if i can get it inside of the car to make a bir more room for my air filter to go into. the thing is can it be done and does anyone have tips or helpers on how to do it? has anyone dont a step my step guid. i have had a search but have not found anything of real help about moving the motor inside.
was discussed here a few days ago bud
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=205626
i read through that, it was quite helpful but can it be done say like making another hole so it sits a bit more tidaly? i wanted to try and get the motor to hidden away somwhere so i can fit some speekers under the dash :)
friking double post. also forgot to add, would it be posible to change the wipers to a left hand drive setup so the wiper motor is on the other side? would it clear enoug of the screen? any views on this would be nice :)
Edited by Paul R on 4th Mar, 2008.
I have mine on the LHS of the engine bay, but it only operates one wiper and you can't use the reset switch. But the wipe is the same.
Ive seen one mounted down near the passengers feet before. God knows how they did it.
Can you couple 2 pipes together??
