Home > Help Needed / General Tech Chat > help!! please!
checkmate
Member #: 2273
middlesex
ive had my car on the road for about two days now
everything is fine apart this one annoying problem...
randomly it would just stop revving whilst driving... i have to turn it off then wait 5 mins before turning it on and setting off again
this only happens occasionally (it could be after driving hard) and not all the time
ive checked the fpr and its reading 3.6 psi at idle... what else could it be?
any help is greatly appreciated... thanks
thasim82
Member #: 1413
is heat sheild between carb and zorst manifold fitted?
had same probs with mine for a while untill i fitted the sheild
there could be a number of faults here ?
is it a turbo ?
dodgy fuel regulator, fuel pump, sticking float bowl valve,?
ignition side, dodgy coil, leads, dizzy cap
you must eliminate these first
anyone else.......?
Nick
Member #: 154
Midlands
could be the fuel tank breather trapped/blocked.
or i'd check the std filter on the fuel tank pick up pipe, i had similar issues cos it was smegged up so removed it.
Dodgy ignition module breaking down ?
i'm with phil on this one,
I had exactly this issue, and it was the dizzy module, if it does it again pull a plug lead and check the spark.
checkmate
Member #: 2273
middlesex
it only happens randomly out of the blue
i have noticed that the filter by the plenum is empty when it happens?
can i just change the dizzy module or do i have to change the whole thing?
If the filter is empty you have no fuel coming to the carb.
You'll have to start at the tank and work forward.
Can you hear the pump running when you try to restart?
those filters can be decieving, they shouldnt be full-full.
Also please remove it ASAP as 3-4psi + boost is easily enough to split one and spray petrol over your hot manifolds...
checkmate
Member #: 2273
middlesex
yes i can hear the fuel pump when turn the ignition on, but when driving its silent/quieter
when its running the filter doesnt get full full.
so i should remove the filter completely? couldnt this be bad?
Nick
Member #: 154
Midlands
not really because you should have an injection type one between the tank and fuel pump anyway if you're using the metro pump/mini tank arrangement.
your pumpis not getting enough power when runnig then,
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Just another daft thought. On the metro setup, there was a oil pressure cut off for the pump. Most people bin it all that, has yours got one fitted?
Other than that, check the fuel lines & change filter.
Edited by Jason G on 8th Mar, 2008.
On 19th Jan, 2010 wil_h said:
checkmate
Member #: 2273
middlesex
i have found that this only happens when the petrol drops to a certain level - about an inch above the pick up pipe?
Put more fuel in *wink*
As above.
checkmate
Member #: 2273
middlesex
ok i know that its definetely not the amount of fuel i have
it happened today doing about 20 on the way home (low revs).
i got out and had a look at some things, found that the filter was completely empty but i could hear the fuel pump buzzing away???
i turned it off for a few mins then started again and let it idle so it could fill up
im thinking its a faulty fuel pump?? could i be right?
and btw i done 20 miles doing 60 without any problems earlier??
checkmate
Member #: 2273
middlesex
and its doing 15 mpg!!! (normal city driving)
is this right?
(8.5:1 with 4 psi of boost)
You need to refit a fuel pressure gauge and see what the fuel pressure does as it cuts out. My guess is that it will die away to nothing as the car cuts out.
checkmate
Member #: 2273
middlesex
yes it does dye away, but this haapens at any rmp - not just on boost
any suggestions as to why my mpg's are so low?
and if i replace the fuel pump what would be a good one to go for?
(atm its standard metty turbo mounted on subframe with side exit exhaust)
Star Mag
Member #: 375
Leicestershire
If all your fuel pipe runs are clear and you have a good power feed to the pump and you are still losing pressure then then i would say its fubar'd! Check everything twice before purchaing a new one though!
