| Home > General Chat > Can I See Someones Nuts, Preferably Nics (Mirage Setup) | |||||||
10th Mar, 2008 at 05:46:31pm
I'm just putting my Mirage manifold back on, up until now I have used standard 5/16UNC nuts on all studs. However, the the two studs that are one-in from the outside are a very tight fit; in fact you have to have the mainifold half off to even get them on. And then getting a spanner on to tighten them is impossible.
10th Mar, 2008 at 06:28:12pm
i used k nuts, there 3/8ths head and when using a 1/4" drive socket life is a doddle, ill find you a link |
10th Mar, 2008 at 06:29:07pm
I know kean uses cap head bolts instead of studs/nuts as his were a pain in the arse too. On 20th Oct, 2015 Tom Fenton said:
10th Mar, 2008 at 06:30:26pm
I hope that UNC is a typo.
Edited by Paul S on 10th Mar, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
10th Mar, 2008 at 06:59:36pm
haha, yes UNF, oops!
10th Mar, 2008 at 07:50:22pm
hmm ill try and remember to get a pic of mine when i go out to my dads later
10th Mar, 2008 at 07:57:01pm
i used some 6 sided k nutsd, then a spanner was easy enough to use i seem to remember. |
10th Mar, 2008 at 08:27:35pm
10th Mar, 2008 at 08:36:56pm
just looked, at one end i'm using a cap screw, the other a 6 sided k nut.
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
11th Mar, 2008 at 06:58:35pm
wil, when i assembled mine, those studs were fouling the manifold, so I shortened them. Also those k nuts Nic was going to link you to are good. I think Merlin motorsport do them
11th Mar, 2008 at 08:56:26pm
I think shortening the studs is the solution. Maybe next time I take it off.
13th Mar, 2008 at 11:32:59pm
Right ive got some pics
14th Mar, 2008 at 07:11:06am
Its not the ones on the centre branch I can't do, its the ones on the outside of the inlet flanges.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
14th Mar, 2008 at 09:30:44am
nic,im glad you've finally got your nuts out for everybody to see. On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
14th Mar, 2008 at 01:05:55pm
Ahh those ones
14th Mar, 2008 at 01:22:20pm
On 14th Mar, 2008 wil_h said:
Its not the ones on the centre branch I can't do, its the ones on the outside of the inlet flanges. Cheers for the photo though, My nuts are not like that. And my manifold id much closer to the studs on the outside of the flange. The nuts on the stud is supposed to be outside the flange. On 13th Jul, 2012 Ben H said:
14th Mar, 2008 at 01:31:58pm
Its not the ones on the centre branch I can't do, its the ones on the outside of the inlet flanges. Cheers for the photo though, My nuts are not like that. And my manifold id much closer to the studs on the outside of the flange. The nuts on the stud is supposed to be outside the flange. hahahahaha wrong, so wrong |
