Home > Technical Chat > Getting rid of the brake servo?
V700BEN
Member #: 2176
hi guys,
i am attempting to clean up my engine bay for my supercharger install, i have put all the electrics behind the dash and now i am looking to get rid of that huge brake servo. i notice that some of the 16v guys have to get rid of it to make room. i am wondering what are my options to replace it with?
Thanks
nothing?
It has a pretty small boost ratio - compared to almost every other car on the road... You could easilly remove it - maybe even make up an adaptor to re-locate your current master straight onto the bracket the servo bolts up to - will save messing about with a new servo / pipework.
V700BEN
Member #: 2176
On 10th Mar, 2008 TurboDave said:
nothing?
so are you saying that i could remove the big drum section and plum the master stiaght to the pedal?
Basically yes you could, would need some fabrication needed to mount a master cylinder to the servo bracket though.
V700BEN
Member #: 2176
is there a master cylinder i can buy that would just simply replace the lot?
http://www.minispares.com/Product.aspx?pid=36659
V700BEN
Member #: 2176
will that work with my metro turbo calipers? and also will i loose any brake perfomance? considering i am going to be uping the power i still want good brakes
A servo doesn't make your brakes better, just easier to push the pedal down *wink*
Bin the servo and the master cylinder, and get a yellow band upright master cylinder, you will also need the brake pedal and the master cylinder base plate to match, a bit of brake line and job done. why bother keeping the bell crank, it too is heavy and takes uo too much room!
sprocket ,will this give a similar feel to the servoed system ? do you change the pedal cos theres a different leverage ?
The pedal feel is actualy softer but the travel is a little longer, obviously. You need to change the pedal because the hole on the end for the clevis is too big. It would also apear that the pedal itself sits a little higher. You need to change the base plate because the hole for the master cylinder is the wrong size and in the wrong place, so makes it difficult to open out.
I like the feel, I think its more responsive than the servo.
Dont forget that all minis up to the late eighties had disc brakes and no servo *wink*
Edited by Sprocket on 11th Mar, 2008.
oooh , thats encouraging , i think a trip to the scrap yard may be in order , i was told the other day that non servo mins had awfull brakes etcetc.
Edited by robert on 12th Mar, 2008.
Mini_Andy
Member #: 432
did a girl tell you that?
johnK
Member #: 690
Norfolk
The servo does nothing for brake performance - its just for girls with weak legs, the mini even in sportspack form isn't what you'd call heavy and doesn't need a servo
bin the servo and gain some brake pedal "feel" and some more space!
If Carling made Mini engines
I wish I had not read this thread.
I can now see myself spending over £100 on a new master cylinder and a trip to the scrappies at the weekend.
johnK
Member #: 690
Norfolk
lol! but at least you'll have good brakes for when you unleash the turbo K grunt!
Good advice. Don't buy a 2nd hand double brake master. They're always junk, and the rebuild kits are expensive!
Get a brand new one, don't skimp on brakes.
V700BEN
Member #: 2176
thanks guys great advice and i ordered a yellow tag master cylinder i will let you know how i get on
I'm going to do the same!
