Home > Help Needed / General Tech Chat > 3RD time lucky
Markie_D
Member #: 1660
Formally Mini_Uk
London
As you know ive been trying to sort out my oil leak which is coming between the front plate and my belt drive cam cover.
well i put it all back with wellseal and left it over night.
turned over the engine few times and left it to see whats what.
checked it and oil coming from the same place.
so there must be a small cap between the 2 holes either side off the arrow.
so im thinking, is there some kind of silicone type of gasket sealant i could use instead of wellseal, as when tighening the nuts up quite abit, dont seem to close the small gap. so hoping the selicone gasket would help more.
You can see where the oil was coming from where the arrow is.
Thanks.
Shit Happen's
yes silicone from the builders mearchants that translucent type cheap as chip
not the bath room white sealer dont use that
anyway mini uk apart from the small problems you have encounterd hows the motor power wise ?
Markie_D
Member #: 1660
Formally Mini_Uk
London
Hi steve,
You forgot my name already lol
only problem with that kind of silicone. wouldn't it be a bitch to get the cam cover off when i come to change the cam belt.
spose i could just place the silicon where the leak is.
well i havn't really give it some yet mate.
To scared lol im joking. well ive only done bout 3 miles lol
as ive been back home. but back down kent now to finish little bit and bobs off on the car.. just one problem after another.
2 steps forward, 10 steps back..
ill just keep going. wanna get mot done before end of the month, as tax runs out, and dont wanna be declearing it a sorn.
can get abit mind fuckin at times when shit goes wrong all the time.
Even the missus has left me lol fckkkk.. i love my mini more the her's she says lol cant even be arsed to let it bother me, plenty more fish in the sea *wink*
cheers..
Shit Happen's
yea for got you name as i deal with many peeps ...sorry
silicone will be ok no worries there use it all ove the gasket area with the gasket
keep batting on and do ever job good so you dont go back to it
Have you put a straight edge (steel rule) on that housing to see if it's flat?
Never tried it myself but a piece of wet n dry on top of a piece of glass should get it flat...
Try using some Permatex ultra black RTV sealant...works a treat! *wink*
Markie_D
Member #: 1660
Formally Mini_Uk
London
Well took the cam off for the 3rd time lol
And in the pic you can see there is oil coming from the back of that little plate where the 3 bolts.
is this meant to happen or not ?
cheers lads..
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
It's abit pissed *surprised*
Shit Happen's
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Is it coming out of that little hole in the plate? I'm sure its ment to do that.
Edited by Jason G on 19th Mar, 2008.
On 19th Jan, 2010 wil_h said:
Leonard
Member #: 806
Cirencester, Gloucestershire
im sure theres meant to be oil in there. have you got the timing cover with a breather on it?
Leonard
Member #: 806
bugger my 1st double post
Edited by Leonard on 19th Mar, 2008.
Yeah its meant to do that,te hole allows oil to pass through to the other bearing face for the cam sprocket, it then drains through the gap around the crank. *wink*
Markie_D
Member #: 1660
Formally Mini_Uk
London
So it's meant to come out from behind that that little plate with the 3 bolts ? i would of thought not, only the little on that plate hole.
Oh well..
Cheers anyways :)
Shit Happen's
Are you 100% it's leaking from this seal. I was once convinced I had this problem, but it was 1/2 moon seal behind the plate that had split.
I would put my money on the half moon seal. Which one do you have? They one with the reinforced wire through the middle or the one without?
If its the one without did you trim it to fit? As they are slightly too big.
Mike
DON's use that much gasket sealant next time. The goo will eventually clog your oilf pickup.
Oh well..
Its only a metal to metal contact so they are not necessarily going to seal, oil is being flung around inside the timing cover anyway by the sprockets and chain so that isn't an issue...sealing the timing chain cover to back plate and back plate to block is important though, as is the half moon seal on the crank.
Cheers anyways :)
Markie_D
Member #: 1660
Formally Mini_Uk
London
I just put the cam belt back on, just to make sure it wasn't the half moon leaking.
Run the engine, and the half moon part was dry :)
the oil comes out quite abit from the cam part. i know oil comes out of course, but how much ?
Im gonna have to mess around with the cam cover to help it seal better, as it is abit pissed by 1m.
So im gonna have to use the silicone, as i really dont want to be taking that off for the forth time lol
Cheers ..
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
Fixed me oil leak :) just 1 more to go now lol
Made more holes and put some counter sunk bolts from the back, and ended up using RTV sealant :) done the job.
Cheers :)
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
I checked every day to make sure it wasn't leaking again. all seem well.
untill 350 miles later, it started leaking again :( can't understand why it would start again :( i dont the best i could. what a downer, coz that was a pain in the ass job to do.
is there a better kind of plates i could buy ?
Shit Happen's
It does also seem as you've mounted the camshaft retainer plate the wrong way.
I'd get shut of that housing and fit one that's flat! Failing that get it ground flat by someone that skims heads?
Markie_D
Member #: 1660
Formally Mini_Uk
London
How do i tell if it's the right way round ?
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
I cant find the same cover as the one i have.
Do you know where i could get one from ?
I've looked around with no luck.
Can't see why it would just start leaking again when it's been fine :(
Shit do happen.
Shit Happen's
