Home > Help Needed / General Tech Chat > Rockers
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I did a search but didn't find quite what I was looking for. I would like some 1.3 roller tiped rockers please but alas no one seems to be selling them (except Minisport), I can only find £300+ full roller rockers or roller tipped 1.5s.
Is everyone happy with their sintered/pressed steel ones? It's just mine are worn on the tips and I would resent spending over £100 on new sintered ones when it used to be £160 for roller tipped.
On 7th Nov, 2008 Nic said:
naeJ
m
Why not 1.5's? Mine goes really well with them on, good idle etc.
just a phase 2 turbo cam.
turbo hogster
Member #: 178
stowmaket suffolk
i had to buy minisport one, the seem ok and are more cam friendly
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
Ian,
have you tried without them?
some one must have a set of pressed steel 1.3 ones
these are stronger than most peeps give them credit for
cheap as chips and gets the job done place an add on the wanted section
i would only use 1.3 ratio with a phase 2 cam
i have some standard one from my spi. yours for £20
its the PRESSED STEEL items which were fitted to cars in the 70s era which are 1.3 ratio ones
the ones you have mini majic are 12.5 ratio cast type
:( pissin spi. lot of crap *happy* oh well now i know ey!
i have some avonbar forged type somewhere, il dig them out .
Jay#2
Member #: 648
I will probably use my stock sintered ones (I know they're only 1.21:1) but as I say they are worn on the tips and when textbook clearances are used they are noisy! I just don't want to spend £££ on full rollers, I could use 1.5s but some peeps report cam wear when using them. I think I am just shocked that you can't buy roller tipped 1.3s anymore! Anyway thanks for the imput guys, I have some thinking to do.
naeJ
m
I guess it's due to the current tread to fit 1.5s to almost everything these days! *surprised*
I got 1.3 roller tips from Mini Sport years ago, they're not ace but they're still working....
Jay#2
Member #: 648
Your right that's what it is. Apparently the "90hp" kit you can get for MPi minis caused the head gasket to fail because the rocker posts compressed and gave a bit taking the tension off the head studs. Might have a look at the Minisport ones then!
naeJ
m
It's the Minisport ones that has got aluminium posts= junk!
miniminor63
Member #: 672
The oversills police
Oslo, Norway
isnt that a bit too much? *wink*
i swear somwhere still does 1.3 ones i was look at some the other day ill see if i can find where it was
http://www.minispares.com/Product.aspx?pid=38323 full set
http://www.minisport.com/acatalog/info_MSLMS0483.html assembaly
:) i dont know if this helps
re-read the post sorry
Edited by Paul R on 24th Mar, 2008.
is it MED does 1.3 roller rockers ?
Ali posts maybe junk, I don't know, but they've lasted 10 years on a 1380 with a 285 cam :)
These are the ones http://www.minisport.com/acatalog/info_MSLMS0483.html
The head lifting could be down to using 1.5 rockers rather then the post material?
I've not had to change the head gasket....
Edited by Bat on 25th Mar, 2008.
Jay#2
Member #: 648
I think MED do 1.5s. Everyone does 1.3 full rollers or just the 1.5 in roller tip except Minisport. Your right Gav it is the 1.5s that have the problems with head gaskets, maybe the 1.3s survive OK. I guess there isn't a market for 1.3s anymore.
naeJ
m
Because?
miniminor63
Member #: 672
Oslo, Norway
I seem to remember that Adrian Dodd wrote something about that once. He also blamed the 1.5 rockers and swapped them for 1.3...
I've had a turbo engine with a ph2 and std rockers and now this with the 1.5's and it idles perfectly each time.
Wear is another thing as i dont do massive mileage.
fab
Member #: 100
Paris' suburb
didn't though about idling, but about global performance?
Its smooth all the way up, little lag and not excessively peaky for a turbo with power all the way to a 7500 redline.
If i like it can slip it in 2 or 3rd or even 4th and it will pull along on idle.
I have yet to see anything that would warrant changing them to 1.3's
*smiley*
all my opinion though, and it is limited *smiley*
