| Home > General Chat > Is there much life left in it? | |||||||
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
22nd Mar, 2008 at 11:17:18pm
Im guessing the answer is no,but impatients is getting the better of me, its a std metro turbo verto clutch has a little meat left on it but not alot, doubt it will last long with 12psi boost? what do you think?
22nd Mar, 2008 at 11:20:37pm
it wont last at all. all depends on the spring, take a look at wil's post about clutches.
22nd Mar, 2008 at 11:23:54pm
Just think about how much work will be needed if it DOES slip..
Edited by Turbo Tel on 22nd Mar, 2008. website:- http://www.terryhunt.co.uk
22nd Mar, 2008 at 11:29:22pm
As Iain says. We know a new one isn't really up to it, so with a pretty shagged one you've no chance.
22nd Mar, 2008 at 11:30:09pm
I know, lol, I just want to get on. The prob I have is I dont have the money at the moment to buy the parts for a non verto setup, and if I did I would want to run it with pre engaged starter.
23rd Mar, 2008 at 12:22:00am
I think I have tucked away somwhere a preverto clutch assembly out of an old 998 engine, can I purchase this http://www.minispares.com/Product.aspx?pid=37926 fit it with an orange diaphram, and un uprated plate?
23rd Mar, 2008 at 12:30:12am
If you have access to a preverto then go for it.. dont forget the wok, slave cylinder and hydraulic hose as well. You may want to reserch the orange/grey pressure plate choice and decide which you want to go to, I can never remember which ones stronger of the two..
23rd Mar, 2008 at 07:01:55am
the ring snap is easy, it come of and on for image as a bearing in a gearbox,
23rd Mar, 2008 at 08:08:50am
Edited by Bat on 23rd Mar, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
23rd Mar, 2008 at 08:39:28am
grey is strong than orange, i just used orange as it was what i had and i wasnt using a lot of boost, i've got a grey and a paddle plate in there at the minute. |
23rd Mar, 2008 at 08:56:54am
On 23rd Mar, 2008 Turbo Tel said:
If you have access to a preverto then go for it.. dont forget the wok, Is there any difference between the woks other than the clutch arm? Isambard Kingdom Brunel said:
23rd Mar, 2008 at 08:59:20am
just the arm and the plunger uses a different bearing |
23rd Mar, 2008 at 09:02:03am
A clutch is an easy job even with the engine in (as long as you miss out the fiddly bolt of the wok).
23rd Mar, 2008 at 10:00:34am
leave the awkward bolt out and slot the other two. makes it much easier |
23rd Mar, 2008 at 10:25:29am
Right then, gonna take the risk and just trow a new plate in it, if that fails I think I can just about scrape the funds together for a pre verto set up, Eeek!
23rd Mar, 2008 at 03:42:53pm
i think the plunger bits are the same though.
You should find it on a search.
