Home > Help Needed / General Tech Chat > another megajolt question about maps
philc
Member #: 1346
bromsgrove
I have looked on the search section and only found the one from BAT which may suit or be able to use as a guide. I still don't get the mapping side of it yet but i will persever.
I have 1380
stage 3 head
VP3c cam
45 webber
any maps that may help would be appreciated thanks again
The clue is in the name, TURBOminis.
Try some of the other Mini forums you may have more luck?
Here's the one I'm running in the British Open (yes the BOC is still N/A but Bat's got my manifolds so now I've got an excuse to drag my feet with the conversion) as a starter:
http://img1.putfile.com/main/3/6716164676.jpg
Note, I've tweaked it since uploading the picture.
Also I'd suggest backing the values off a bit and then setting it up properly on the rolling road.
Here's a few more maps:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=160564
Edited by Rob H on 23rd Mar, 2008.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
that site isnt there anymore unfortunately :( i could build a new on though with all the maps on as files too if theres interest for it?? :)
jamesfawcett
Member #: 218
When i asked for megajolt maps on here before, most of the people that contacted me using megajolt had NA engines...
That map of mine should be pretty close for you Phil :)
Mines 1380, Piper 286 cam, very big valve head, 1.3 rockers, 45 weber.
100lbft & 125bhp *wink*
Gavin:)
philc
Member #: 1346
bromsgrove
thanks guys, always helpful as ever..
feebeluk, i think that would be a great idea, i have spent ages looking on other sites without much success
Edited by philc on 23rd Mar, 2008.
philc
Member #: 1346
bromsgrove
sorry if this sounds dumb, looking at BAT's map the load starts in 0 as Robs load starts in 30, just wondering why that is.
Mine runs on TPS, which if you've got a weber and a "race" cam is the way to go, as it's difficult to get a steady map signal at low revs.
I'm guessing Robs is using a MAP sensor, in which case the scaling is different.
Which are you running MAP or TPS?
philc
Member #: 1346
bromsgrove
i'm using a MAP as i was led to believe it gives a more accurate reading
In that case you'll need to connect it to both pipes on the manifold and put a fuel filter in the MAP pipe too.
Hopefully the fuel filter will dampen out the fluctuations.
Yep, I'm running a map sensor.
philc
Member #: 1346
bromsgrove
already put pipes in, gud idea about the filter, had not though of that
jamesfawcett
Member #: 218
Ok ive made a new megajolt section on my site, so far ive typed in Turbo Tel's turbo map and put it up for download... please add yours if you can for everyone else :)
http://www.jamesfawcett.co.uk/ then click on megajolt!
Im going to do more work on it, and type in everybody elses to upload too if thats ok with everyone?? :)
jamesfawcett
Member #: 218
If anyone else has any maps, please email them to me mail@jamesfawcett.co.uk and ill add them on the site, cheers
