| Home > Help Needed / General Tech Chat > Starting from scratch (engine) | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
24th Mar, 2008 at 10:30:43am
After a misshap over easter i have killed my n/a engine that had a long term eaton conversion planned for.
24th Mar, 2008 at 11:32:36am
If you dont want to have the engine out again, then diff and drop gears have got to be a top priority. Along with a good cam and a bottom end that is up to the job.
In the 13's at last!.. Just |
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
24th Mar, 2008 at 03:34:38pm
if you're buying a new turbo, manifold and head, then theres no point paying lots for a turbo engine, as its not much different to a non turbo on the inside.
24th Mar, 2008 at 03:37:47pm
fair point,
24th Mar, 2008 at 03:39:27pm
On 24th Mar, 2008 Leonard said:
if you're buying a new turbo, manifold and head, then theres no point paying lots for a turbo engine, as its not much different to a non turbo on the inside. true, but im strugling to find any engine at the moment :( |
24th Mar, 2008 at 03:43:06pm
First strip down your engine and see what state it's in. Then you'll avoid putting nice new heads/turbos and an engine that won't last. On 7th Nov, 2008 Nic said:
24th Mar, 2008 at 04:43:31pm
24th Mar, 2008 at 06:16:24pm
On 24th Mar, 2008 Bat said:
Hi, First start at the beginning.... What do you want from the engine? Daily drive or all out race...? What sort of power output are you aiming for? Bottom end to base it on... Anything 1275 A+ will do as you'll be rebuilding it anyway... Cheers, Gavin :) cheers for all the help so far guys. right, slight change of direction but still on topic. got a second pair of eyes round thisarvo to look at the engine i already have, looks like the block itself is fine but the gearbox suffered, a few teeth on various gear wheels are damaged, so all in all i have the engine and no longer looking for another. what am i looking for....basically all out racer, but i wont be racing it, if that makes sense. i want a stupidly quick road car that i will frequently visit santa pod with, at present im not looking to take it on track but you never know. power output, again, as much as i can get without getting silly on prices. i have never built a turbo a series so not 100% on final costs for x bhp output. i am totally commited to doing as much if not all the work on my own so i am looking to start 1275 as i cannot bore the block etc, plus i think there is something "nostalgic" (if thats the right word) about the 1275 block and squeezing so much power out of it. lets say i was to get the T25 hybrid from mirage and wanted to spec the engine around that, maybe thats easier? Edited by Simon on 24th Mar, 2008. |
24th Mar, 2008 at 06:22:28pm
Edited by Bat on 24th Mar, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
24th Mar, 2008 at 07:54:51pm
Turbo hogster on here builds a good s/c box, builds them for mini williams which is a good testiment to his std of work, he built one for me but I have not ran the engine yet, top bloke, great service and doesnt charge the earth.
Edited by shane on 24th Mar, 2008. |
27th Mar, 2008 at 07:23:57pm
Right then chaps, I'm sure you will all revel in this one...I would like you to spec me an ideal engine with a budget of £2500 max! The target is max bhp for the £'s. and where to buy the bits from.
27th Mar, 2008 at 07:40:23pm
mirrage setup, benross head, ps1 cam std rockers//1.3 roller. the cv box will be the downside as you will have piddely squat left after building it and a hiff 44 to turbo rebuild kit
27th Mar, 2008 at 11:14:09pm
minispares crosspin diff. minispares clubman gearset new bearings, minispares pre vertro lightend flywheel andl ightend back plate AP race clutch plate, gray pressure plate
Edited by BENROSS on 27th Mar, 2008.
27th Mar, 2008 at 11:22:27pm
Ive had both of the mirage turbos
Edited by Nic on 27th Mar, 2008. |
