Home > Help Needed / General Tech Chat > sorted!
timboc
Member #: 2043
rite well my engine is all in and running now, got a few little bits to sort out and tidy up, it's a 1293 with phase 2 cam running standard 4psi boost now i cant afford a rolling road tune at the mo so want to run it in and make sure everything is ok. what would be the best timing to run for this to be safe? not too worried bout economy jus performance and reliability.??
cheers tim8-)
6 DBTDC, vac disconected to the distrib.... and give it some beans
it will be fine on that boost if the mixtures right and on the timing figure above
please read this link carefully ................. http://www.mototuneusa.com/break_in_secrets.htm
Edited by BENROSS on 2nd Apr, 2008.
El Potter
Member #: 2169
Malta (Ex. Scotland)
Steve, that's an interesting page there.
Is it true though?
As the writer says,it goes against the grain so much I find it difficult to believe,though it makes sense mechanically.
Sorry O/T
Warning:Stig in Training
jamesfawcett
Member #: 218
Bingley, West Yorkshire
i feel hypnotised by that writting on that page, seems so well written that it has to be true! hehe
yes trust me its right and born about by my own motors
and many peeps i have spoken to over the years
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I'm going to try it. :)
This is going to sound really dim. You build an engine for race/track use. You fire it up to check for leaks etc. How do you do the run in sequence prior to rolling road? The engine has to be under load, driving on the road is out of the question.
I gather you run it in at the rolling road?
Edit; Theres also a very similar method in those Speed pro books. :)
Edited by Jason G on 2nd Apr, 2008.
On 19th Jan, 2010 wil_h said:
Give me the keys and look the other way, I'll run it in for you! *tongue* LOL
Somewhere on that site it tells you how to run your engine in on the dyno :)
Jason G
Member #: 1459
En-suite user
Braintree, Essex
okies mini13!!!!!!!!! Anyone got a taxed, mot'd metro I could borrow??? *wink*
timboc
Member #: 2043
cheers benross, is tht at 1500 rpm?
