| Home > Technical Chat > MPI on a carb - Mj connections | |||||||
169 Posts Member #: 409 Advanced Member Bristol |
5th Apr, 2008 at 08:54:22am
Hannibal: There are two ways we can do this: the easy way and the hard way. In a few minutes my friends and I are going to come down on you like your worst nightmare. You're gonna wish the Earth had opened up and swallowed you whole.
5th Apr, 2008 at 09:05:24am
In short not I've not connected a MJ up to an MPI lump, but I can't see it being any more tricky than any other engine, assuming the MPI flywheel is a 36 - 1 arrangement. Don't worry about the cam sensor as MJ doesn't use them.
5th Apr, 2008 at 10:04:45am
Edited by Bat on 5th Apr, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
5th Apr, 2008 at 02:01:07pm
I would have thought the coil pack would be fine, after all it is just a wasted spark coilpack the same as any other. I'm planning on using an MPI one with my MegaJolt in any case, just so I can use the proper MPI leads.
5th Apr, 2008 at 06:51:07pm
Just a thought; are the MPI coil packs the same impedance and the Ford ones? Obviously it would still work but over time what's it going to do to the coil?
6th Apr, 2008 at 08:20:24pm
6th Apr, 2008 at 09:36:55pm
You cant measure impeadance without specialist test equipment, you can test the reistance though Edited by Sprocket on 6th Apr, 2008. On 26th Oct, 2004 TurboDave16v said:
7th Apr, 2008 at 11:43:56am
If you don't run the correct era Ford Coil Pack the EDIS module does burn out...
AlexF |
Its going to be much of a muchness, as these coils work in the same way and from what ive seen the dwell times are roughly the same
