| Home > Help Needed / General Tech Chat > Recirculating Dump valves | |||||||
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
13th Apr, 2008 at 06:54:29pm
Ive personally not had any experience with these, a search didnt reveal the answers I was needing. Firstly do they come in piston and diaphram type? As I take it I wuld be neding a diaphram type. Secndly, where does the recirc air go back into the Inlet tract? Can any one recommend one, thinking forge?
13th Apr, 2008 at 06:55:54pm
You would vent the air into the intake pipe before the turbo, after the filter.
13th Apr, 2008 at 07:03:10pm
Forge make them, or Turbosmart make some really good ones.
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
13th Apr, 2008 at 07:05:47pm
yeah, just like the 20vt vag setup. If you want to try it out you can get cheap plastic bosch ones for about £8. They are the diaphram type. |
13th Apr, 2008 at 09:53:30pm
ARe the piston type versions of these usable, or do they suffer the same seal swelling issue as the atmospheric ones?
13th Apr, 2008 at 11:06:19pm
14th Apr, 2008 at 08:07:55am
The standard Sierra Sapphire Cossie ones (2WD and 4X4) are the Bosch plastic recirculating ones and often come up cheap on eBay as the boy racers get rid of them to fit atmospheric dump valves instead. Schrödinger's cat - so which one am I ??? |
14th Apr, 2008 at 09:16:36am
Peugeot 2.0 T stuff also uses the Bosch plastic recirc dump valve, I bought one recently for another project for £6 off ebay.
14th Apr, 2008 at 05:39:06pm
yep they were std fitment on lads of stuff,
![]() 902 Posts Member #: 111 Post Whore Loughborough |
16th Apr, 2008 at 11:11:07am
Is a recirculating dump valve the same as a supercharger bypass valve? both work on manifold vacum don't they?
