Home > Help Needed / General Tech Chat > Hmmm, running problems. With vid.
hammoj28turbo
Member #: 1502
Aberdeenshire, scotland.
Right, i set up the carb the best i could, not got a colourtune kit yet tho so its just rough.
Got a few problems though and im a bit worried now.
It idles fine, and revs alright for a while, but then after a while it just seems to stutter and likes to backfire a lot. Is it screwed?
Will i just have to wait til its set up properly and electrics/timing have been checked? or should i be worrying now?
Iv heard backfiring is bad...:(
heres a vid.
http://s91.photobucket.com/albums/k317/ham...nt=DSCF1139.flv
What's your fuel pressure when this happens?
hammoj28turbo
Member #: 1502
Erm, im not sure what it is. Not got anything to check it.
have you got a coolent leak from your rad??? mine sounded a bit like that when it was overfueling, alot
hammoj28turbo
Member #: 1502
Lol, nah. I spilled water on the top when i filled it up.
Hmmm, id better wait til i get hold of a colourtune kit then and then see how it is.
Ric
Member #: 36
Basingstoke
get the plugs out, should give you a rough idea as to whats going on.
pot_dan
Member #: 326
bradford, west yorks
if its running so rich that its running badly then you should be able to smell it from the exhaust.. even see it? also as ric said, plugs are a good indication:)
http://turbominis.co.uk/car/105/
Zeemax Power
Member #: 393
Oulton Park
mine was doing that when it was running to lean, and if you have a cammed engine colour tune is no good. i brought one the other day shockin that bad you can have mine for the fact has to run rich or doesn't run
http://www.Zeemax.com
That's the difficult thing to tell, too rich or lean will make it run like that.
The smell of fuel out the exhaust or black plugs will be the give away though *wink*
hammoj28turbo
Member #: 1502
Zeemax Power, Its just a standard engine so im assuming colourtune would be fine?
Yeah, there was a smell of fuel so im assuming its too rich. Im going to get a colourtune and a timing gun for when i next go home and try set it up the best i can.
I had a fiddle this morning before i left and its running a fair bit better but i cant do anything until iv got the right kit.:(
Richie
Member #: 628
sounds like its a fuelling issue ? what size pipes did you use from tank to reg ? and what pump was it ?
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
hammoj28turbo
Member #: 1502
I used 8mm ID pipes from and back to the tank. Its an Spi tank with the Spi Pump.
hammoj28turbo
Member #: 1502
Right, im going to try get a colourtune kit, i know they are not ideal but i am in a tricky situation.
I cant get to a rolling road any other way than driving the car there.
I have to get it set up so i can drive it to an mot then take it to the rolling road.
Any suggestions what i should do guys?
My plan is get it running reasonably ok with colourtune and get the timing set. Then get it mot'd and only drive it carefully to the rolling road to get set up properly.
Edited by hammoj28turbo on 26th Apr, 2008.
That should do you :) If it's miles out at the MOT get them to adjust it something like for you *wink*
hammoj28turbo
Member #: 1502
Cool, i now have an action plan. Nice one.
Cheers.:)
