Home > Help Needed / General Tech Chat > Problem with MJ, and I cant use a computer!
shane
Member #: 1246
Lowestoft, Suffolk.
I have loaded a map onto the MJ but I did it on my pc, and not had a problem. I borrowed a laptop and have loaded the software on, but when the program is running it shows a message at the bottom of the screen "unable to open port" ive checked the settings for the port in device manager and compared the settings to the pc, but cant get it to work, any advice?
Shane
Are you using a real com port on the laptop or a usb adaptor?
shane
Member #: 1246
Lowestoft, Suffolk.
Using the com port, rs32. Cant get my head round it?
Shane
AFAIK there's only 23 things that can cause this;
either another program is using the com port
or you've not got the same com port number in the MJ software as the com port number for the laptop.
shane
Member #: 1246
Lowestoft, Suffolk.
I checked the port no in the mj prog via the tools menu. How do I check to see if another program is using the port?
Cheers Gavin
Shane
It's a look and see process, check for things like pda software, MS active sync, dial up modem sort of things...
What are the com port numbers for the laptop and for MJ?
Edited by Bat on 26th Apr, 2008.
shane
Member #: 1246
Lowestoft, Suffolk.
Well I had to return the laptop last nite, so cant check till I get it back, but pretty sure they was both set to com port 1?
Shane
miniboo
Member #: 2253
Las Vegas, Brit in the States
did you have the port on the latop set to the correct speed and with the correct start/stop bits set?
Edited by miniboo on 27th Apr, 2008.
Andymini
Member #: 438
London
You are using a straight though serial cable, and not a null modem one?
shane
Member #: 1246
Lowestoft, Suffolk.
Yes I compared and adjusted the speeds on the laptop to match the ones i knew worked on the computer.
I cant answer that as I dont know the difference, sorry, im useless with computers
Shane
miniboo
Member #: 2253
if it worked with the pc then the cable must be ok.
might have to take the pc out into the garage!!!
shane
Member #: 1246
Lowestoft, Suffolk.
Lol, dont joke about it, if I cant get it sorted the im going to have to take my pc when it goes on the rollers!
Shane
Turbo Tel
Member #: 588
Delaware, USA
Shane
Its Usually but not always com port 1, it depends on windows, I have seen com port 2,3,4
go to control panel
click on system
click on the hardware tab
click on device manager
open the ports (click on +) and see what com port is listed.
double click on it
click on the port settings tab
set:-
Bits per sec =4800
Data bits =8
parity=none
stop bits=1
flow control=none
Hope that helps..Terry
Edited by Turbo Tel on 30th Apr, 2008.
shane
Member #: 1246
Lowestoft, Suffolk.
Cheers Tel, will that when I get the laptop back, the bits per second, on my pc im running 4800, and that works, what does changing it do?
Shane
Edited by shane on 29th Apr, 2008.
Turbo Tel
Member #: 588
Delaware, USA
You are correct, The setting should be 4800, though it works at 9600 (the wonders of computing!!) I guess the MJ program actually does the configuration for you so this may be mute.. but still worth checking.
I have edited the post to prevent confusion..
Autosportslab has some info on using hyperterminal. You can find it under
start->programs->accessories-> communications.
cant link it so heres an extract.
Troubleshooting with Hyperterminal
Open up Hyperterminal. create a connection, and configure it to connect directly to the COM port you are using for the MJLJ.
When it asks for the communication settings, use the following:
Bits Per Second: 4800
Data Bits: 8
Parity: None
Stop Bits: 1
Flow Control: none
When you get to the main screen, send a capital 'C' to the controller. you won't see what you type echoed on the screen, but the controller should 'reply' with what looks like a sequence of random data. This simulates the Configuration software requesting the controller's current configuration
Pressing 'S' returns the current runtime status; You will see only a few characters displayed.
If the above does not work, or if Hyperterminal indicates a COM port or communications error:
i cant find the hyper terminal bit..
Click Start, all programs, accessories, communications. Assuming you're running XP *wink*
shane
Member #: 1246
Lowestoft, Suffolk.
IM still really struggling with this LOL, have manged to got the software to display "timout reading runtime data" instead of showing "could not open port" but I cant retrieve maps or load maps to the ecu, this is getting really frustrating! Any thought appreciated.
Shane
Turbo Tel
Member #: 588
Delaware, USA
When you looked at the ports how many did you find? There is most likely at least 1 maybe 2, one will be the serial connector, the other the modem. They dont always come up 1 and 3 so if you see any ports in the device manager try each in turn.Also poke around the modem settings in Control panel and try to find out what com port the modem is on on then you will know it aint that one!
Did you try hyperterminal? it usually only lists active ports.. If it only shows one then it may be the modem..and that could be the problem. sometimes people disable the serial port in BIOS because they feel they wont be used and then cannot be seen by windows.
The "port not found" error probably means there is not a serial line on that port, the "timeout reading data" probably means that there is a port but its the wrong one and you may be trying to use the modem.
miniboo
Member #: 2253
"timeout reading runtime data" can also mean no power to the MJ
Turbo Tel
Member #: 588
Delaware, USA
Correct,
but I am assuming you know that as you are able to talk to the MJ from your PC, its the laptop that seems to be a problem..Yes?
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Or maybe he ran the MJ unit off a 9V battery when using the PC before is was wired in? Check your live maybe?
On 7th Nov, 2008 Nic said:
naeJ
m
shane
Member #: 1246
Lowestoft, Suffolk.
I checked all of the above, and totally lost my patients with it and gave the laptop back, I ended up taking my Pc with me to the rollers, wasnt ideal but it done the job.
Tanks for the help guys
Shane
Turbo Tel
Member #: 588
Delaware, USA
Shane
Next time answer the questions and we may be able to help you...
Edited by Turbo Tel on 8th May, 2008.
shane
Member #: 1246
Lowestoft, Suffolk.
Yes tel it was the laptop causing me the problem.
Shane
Shane
