| Home > Help Needed / General Tech Chat > cant upload map onto MJ.....help | |||||||
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
29th Apr, 2008 at 09:50:39pm
not to sure if im using the right software or not but how can i check?
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
29th Apr, 2008 at 09:59:48pm
Whaen you have got the map on the screen, click "write ignition configuration" then the icon next to it, commit to flash this should work, do you have power to the mj? I spent hours trying to work this out before realising the unit needed power.
29th Apr, 2008 at 10:04:14pm
On 29th Apr, 2008 shane said:
Whaen you have got the map on the screen, click "write ignition configuration" then the icon next to it, commit to flash this should work, Shane ive figured that bit out but il double check the live in the morn, also when the car is running should i get some sort if 'moving' display?? i wired it in on an ignition live through a fuse along with one for the coil and edis unit... On 2nd Oct, 2009 Vegard said:
29th Apr, 2008 at 10:09:09pm
When its running the a blue box should move around high-lighting which area of the map your in. You'll also have the ignition advance gauge and rev counter showing the relivant readings.
Edited by matty on 29th Apr, 2008. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
30th Apr, 2008 at 11:50:01am
ok the fuse was crapso i changed it and now i have a tach reading,
30th Apr, 2008 at 09:58:07pm
Edited by Bat on 30th Apr, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
1st May, 2008 at 09:22:45am
Did you get this sorted last night mate?
In the 13's at last!.. Just |
1st May, 2008 at 04:08:34pm
yeah, ceers gary,
1st May, 2008 at 05:19:46pm
Well done mate! Let us know your results.
1st May, 2008 at 06:18:31pm
just popped up there on the way thru. so far its made 178ft/lb and 156bhp@ 12psi and the tester says its still got more to go!but im well chuffed,
![]() 1014 Posts Member #: 238 Post Whore essex |
1st May, 2008 at 07:00:15pm
nice one ron! let us know the final results...have you taken it to atspeed? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
18th May, 2008 at 10:59:01pm
Top day at Brighton Ron.
On 19th Jan, 2010 wil_h said:
