Home > Help Needed / General Tech Chat > who sells weber boxes?
welshdan
Member #: 1111
s wales
who sells good quality weber bulkhead boxes?
I dont think anyone does, theyre more the type of thing you get made to suit your needs. Some people use a battery box though.
I suppose I could fabricate onr for you at a reasonable price if you have no luck. PM if interested.
Paul
I modded a battery box.
You just need to adjust the flange on the box.
You should always adjust the flange on the box whenever you get the opportunity! *wink*
welshdan
Member #: 1111
s wales
lol. cheers. have a spare one kicking about. a member on here milibar? used to make the turbo ones. was wondering if anyone made high quality weber ones. its only for a turbo conversion, to give clearance for the carb. its an spi subframe, is there any need at all for a weber box?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Should be quite simple to make one yourself. Do a cardboard one first to check dimensions if your unsure. Once your happy with it, flatten it, then you have a template to make one out of steel. :)
On 19th Jan, 2010 wil_h said:
welshdan
Member #: 1111
s wales
will i need a weber box for clearence? i have a turbo box, and am using an spi subframe.many thanks
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Are you running a turbo or a weber?
welshdan
Member #: 1111
s wales
turbo. thought the weber box would give clearence around the carb. plus you never know what engine will be in there in the future..
Jason G
Member #: 1459
En-suite user
Braintree, Essex
With SU/turbo setup....you don't need a weber box. But while the engines out, fitting both won't do any harm.
welshdan
Member #: 1111
s wales
thats what i thought.am doing a full rebuild of the car so just as well to do it now.cheers
Jason G
Member #: 1459
En-suite user
Braintree, Essex
:cool:
Simon
Member #: 1865
Norwich, Norfolk
not tried avonbar? https://www.speedgenie.co.uk/avonbar/bulkhbox.html
