| Home > Help Needed / General Tech Chat > seperating gearbox and block | |||||||
8th May, 2008 at 06:08:56pm
at the weekend with some help of ollie i striped one of my engines, i have it in many peices but i cant seem to remove the block from the box, i have undone all of the nuts an bolts holding them together that i can see.
![]() 514 Posts Member #: 2169 Post Whore Malta (Ex. Scotland) |
8th May, 2008 at 06:36:07pm
If the gearbox stilll has the diff on,turn the whole engine/box combo onto it's side so the diff is touching the ground.The weight of the engine alone should break the seal.
Warning:Stig in Training
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
8th May, 2008 at 07:13:47pm
Ive lifted the engine a little at one end (via crank tail) and struck the gearbox casing with a hyde mallet in the past on stubborn ones, but double check you have removed all the fixings!
8th May, 2008 at 07:31:17pm
yeah all the fittings are off, i gave the block a good few whacks with a copper+hide mallet but not the box, i will try both ways. its just im trying to seperate them for neil to have the block Drives
8th May, 2008 at 11:24:37pm
BFH Crystal Sound Audio said:
9th May, 2008 at 06:49:25am
make sure you have got the bolt out from behind the timing cover this ones always get missed always looking for them bigger bunches of bannanas |
9th May, 2008 at 06:07:12pm
didnt realise there was one there tbh i think i have all the bolts off of the engine lol :_) ill have another look 2moz :) it will be seperated Drives
9th May, 2008 at 06:44:54pm
10th May, 2008 at 06:06:38pm
That bolt behind the timing cover has caught me out in the past too easy to miss. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
10th May, 2008 at 06:08:20pm
On 10th May, 2008 matty said:
That bolt behind the timing cover has caught me out in the past too easy to miss. It caught me out in april when I tore my 1275 down. On 7th Oct, 2010 5haneJ said:
![]() 214 Posts Member #: 1574 Senior Member Malta |
10th May, 2008 at 06:14:49pm
A few gentle taps around the case with a soft head mallet has always worked for me.
10th May, 2008 at 06:18:01pm
On 8th May, 2008 El Potter said:
If the gearbox stilll has the diff on,turn the whole engine/box combo onto it's side so the diff is touching the ground.The weight of the engine alone should break the seal. At least it did on mine. Sorry for the rubbish explanation btw. i gave this a shot first as it was the first one to be put up, safe to say it worked perfectly :). shame i forgot to take out the dizzy drive before trying to remove the crank and pistons :( cheers for the help people :) Drives
