Home > Help Needed / General Tech Chat > Braided oil feed pipe
I'm thinking of using one of these to make a bit more space for the intercooler:
http://www.minispares.com/Product.aspx?pid=38538
The intercooler core is quite deep and is currently fouling the solid block to filter pipe.
Anyone use one of these?
Please.
Ah, didn't know minispares did those,
TBH they can only be a good thing in comparison to the std banjo fitting,
I normally use an old oil cooler pipe, but these will sit closer to the block due to the 90 degree bend.
calver does some on his site also of various types, might be worth a look.
i have 1/2" bsp fittings for both of these if you want to use one of the generic oil cooler pipes, any use?
That's cheap *surprised*
miniboo
Member #: 2253
Las Vegas, Brit in the States
apparently they are very good for the flow of oil.
Thanks Guys.
Joey - you have a PM.
I'm inclined to get one made up with a 90 degree bend at the banjo end and then a 45 degree bend at the filter end so that I can route it around the Intercooler.
I thought I knew of a site where you could order custom braided oil pipes online. Merlin and Europa don't do it - any ideas?
Edited by Paul S on 10th May, 2008.
Give Think Autos in Twickenham a call.
http://www.thinkauto.com/
They've been very helpful in the past.
redwing
Member #: 1574
Malta
I always get mine made up to suit as I've never had an oil cooler in a position that a standard pipe will reach. A good hose manufacturer will sort you out best Paul
