Home > Help Needed / General Tech Chat > Spi fuse box wiring
lil stu
Member #: 837
rugby
Hi guys,
we are currently retro fitting a spi cooper engine into me mates
car,
weve got the complete engine and loom but there was no fuse box with it,
ive been studying the wiring diagram for days but cant figure out which wires go together.
the wire colours dont match the diagram either i dont think,
i know it must me missing something, so if anyone could offer any advice that would be ace,
cheers stu
Erm, struggling with this one, any more details please?
What diagram are you using?
What age car you fitting it too?
What have you got where the fusebox was?
And so on......
The engine loom on the SPi doesnt have a fusebox, and if you are not using the injection system, you wont need the loom anyway.
Or
are you looking to install all the injection gubbins in a non injection car? Do you have the body loom and the engine loom?
Very confusing what you are trying to acheive with the description you gave
lil stu
Member #: 837
rugby
ok sorry
will try again.
we have an spi with injection system, and ecu,
we have the engine and body loom.
its the fuse box with the four fuses that we are missing,
is it the power distribution fuses, with the ignition wires going into it.
we are not sure which wires need to be fused together,
we are trying to use the pre 96 wiring diagram for ignition and power distribution (very unsuccessfully)
hope this is more useful
cheers guys
Take a look at this diagram
http://www.teamtorque.co.uk/pics/diagram.pdf
Can you tell me which fusebox it is as there's a 4 way in the car and a 2 way in the engine bay, or is your the one with a big block of fuses on the bulkhead?
lil stu
Member #: 837
rugby
its the box which is attached to the bulk head in the engine bay, same as the carbed models i think.
i dont really understand that diagram im affraid sorry
thanks for the help
stu
There isnt much different on the SPi body loom between the carb and and SPi models, where the power distribution and fuse box is concerned. Rover was very consistant when it came to wire colours and their use.
How many fuses, what colour wires?
lil stu
Member #: 837
rugby
4 fuses will find out the colours as soon as possible
cheers guys
lil stu
Member #: 837
rugby
right guys, i finally got round to my mates to see whats goin on, we managed to sort the wiring, it was very similer to a clubman.
its not running yet,
what i would say is the injector assembly, is making a clicking sound for about 30 seconds after the key has been removed,
is this normal?
ive never had any experiance with spi's
cheers guys
Probably the stepper motor for the idle speed. Don't worry about it until you got it running.
lil stu
Member #: 837
rugby
cheers mate
