Home > Technical Chat > Clutch Question
greymini78
Member #: 2408
surrey / ewell area.
I have been informed by an engine builder that it is better to use a pre a plus clutch as u have more options to upgrade? if so can i keep the verto slave?
by pre A+ he means pre verto,
but yes on both counts.
greymini78
Member #: 2408
Thanks for the quick mate*smiley*
Jay#2
Member #: 648
Northern Ireland (ex AUS)
You will need the pre-verto clutch arm though as its longer.
On 7th Nov, 2008 Nic said:
naeJ
m
redwing
Member #: 1574
Malta
I switched to pre verto on my metro trubo A+ engine and its great. You do need to get the extra long arm as Jay says.
Ric
Member #: 36
Basingstoke
I didn't think you could keep the verto slave...
But yes, with the help of others I did this a couple of weeks ago. Way better than the metro verto setup.
greymini78
Member #: 2408
How bout just losing the bracket the slave cylinder sits on rather than changing the arm that would get rid of the need for a longer arm?8-)
I think you'll need the leverage of the longer arm to operate the stronger clutch.
