| Home > Help Needed / General Tech Chat > SPi to MPI! | |||||||
20 Posts Member #: 2316 Member Greece |
19th May, 2008 at 08:00:06am
Hi I want to make my mini SPi to Mpi, what parts i want and which are the mods on wiring loom to work the MPi ecu? |
19th May, 2008 at 11:23:37am
why?:S |
![]() 2102 Posts Member #: 432 Post Whore Swindon |
19th May, 2008 at 11:56:30am
carb for the win!!!! |
19th May, 2008 at 12:25:49pm
Different Flywheel, Not sure if SPI has a cam shaft sensor. Theres loads of differences. I wouldnt bother, go Turbo. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
19th May, 2008 at 02:48:52pm
Another vote for
19th May, 2008 at 03:14:31pm
I just voted! On 13th Jul, 2012 Ben H said:
1050 Posts Member #: 764 Post Whore Staffordshire |
19th May, 2008 at 04:45:22pm
On 19th May, 2008 MikeRace said:
Not sure if SPI has a cam shaft sensor. nope it doesnt... spi pretty much works as an electronic carb |
20th May, 2008 at 08:01:33am
xm thanks, but I made myself an inlet with rover's 214 Gsi throtle body with the same stepper motor and tps and I want to use 1 or 2 injectors:).Maybe i want an other or an external ecu to manage the second injector!
20th May, 2008 at 06:36:33pm
21st May, 2008 at 07:51:54am
thank you guys Edited by jimi on 21st May, 2008. |
21st May, 2008 at 09:37:31am
No ECU will be plug and play with the rover loom ecxept for one new Megasquirt variant that is specificaly designed for direct replacement of the rover Mini SPI ECU, it will not do what you want it, as you do not have a standard set up anymore.
21st May, 2008 at 10:07:27am
good, I'll try to bridge the two injectors with spi MEMS and I use an adjastable fuel pressure regulator. This is my first idea, at future I'll try an MSII |
21st May, 2008 at 10:35:33am
I'll try it.. but did VEMS works at the same wiring loom:$??
