Home > Help Needed / General Tech Chat > good rolling roads in west midlands
philc
Member #: 1346
bromsgrove
I need a good rolling road that can configure megajolt. I have previously used collins with no problems, he said he could do it, but have red on other forums he is better with 998's rather than 1380's. I have previously used the one on dudley, but didn't rate it at all. any suggestions would be grateful.
Carl
Member #: 95
liverpool-on-sea
surely engine size has nothing to do with it?
mikeanics in congleton just up m6 rekon bout 70 miles away from you could be worth the trip
M111KYP
Member #: 1812
Live in birmingham and work sheffield
i used one in dudley area think it was called Hi-tec performance, they did a good job but was only running a dizzy not megajolt
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
whent down to mikaniks last weekend did not manage to map it as so fueling problems (he had changed some pipes around) don't get me wrong he is suposed to be the dog bollox brother in law uses him all the time, he got it running on the megajolt but admitted he had only see one other turbo mini about a year ago, but I am sure other people on here have said they have used him
Anton
Member #: 764
Staffordshire
collin is goos with standard and stage 1 lumps... he aint too good when it comes to highly tuned lumps... he tends to rely on win su too much.
alandavies215
Member #: 1844
the bloke that done mine was dave , cause there two rolling roads down there mikanics it is a four wheel drive and next door is the two wheel drive same people own to two , omex have a lot to do with them
philc
Member #: 1346
bromsgrove
what about skip brown, i know they have more dealings with pugs. i just want it doing right the first time, really pisses me off when you have to keep going back because of this and that
philc
Member #: 1346
bromsgrove
anyone used slark engineering's rr yet
http://www.slarkraceengineering.co.uk/rollingroad.htm
Aldon have an RR and are in your area.
http://www.aldonauto.co.uk/shop/page.asp?id=services
philc
Member #: 1346
bromsgrove
thanks, been there before did not rate them at all. have spoke to slark, said have not used megajolt before, but will be happy to give it a go. Wish i had a rr myself
What about these?
http://www.mikeanics.co.uk/index.htm
What spec engine you running Phil?
philc
Member #: 1346
bromsgrove
1380 na. stage 4 head, vpc3 cam, 3.4 diff,sc box, 45 webber
This should be close enough....
philc
Member #: 1346
bromsgrove
thanks, you have already sent me this one, so good for a base line, will still need rr for jetting etc
That'll be my goldfish memory then! *surprised*
Sids tune shop is where I had it done.
He's now moved to somewhere in brum, but I got no further details.... :(
