Home > General Chat > Decompression gasket
Gavin Wakely
Member #: 793
Are these any good ? I've only seen the 2 thickness's that Minispeed sell.
No!...... IMHO! there junk and will lead you into problems
you are better sorting the problem at route level ..........................................(ie) altering the combustion chambers
Gavin Wakely
Member #: 793
I didn't want to go that far ! why are they crap (Cant take high boost?)
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
2 chances of a head gasket failure.
Edited by Jordan on 23rd May, 2008.
Gavin Wakely
Member #: 793
I assume its a plate and 2 gaskets ? (I thought it was 1 gasket but thicker)
captain_cabinet
Member #: 1901
Bolton
Yes, it's a plate and 2 gaskets. I have one fitted with the Vmax supercharger kit.
Hope to be in a position to change that in the future but won't have the chance for a while so will have to stick with it!
Chris
how much is the kit???
i could do you the work for the same price, postage included ..... maybe!
jamz
Member #: 2292
Tool
Herne Bay, kent
dont use the decompression plate... my friends had the gaskets go bad and now need alot of work to block and head
imo benross is cylinder head god haha
well worth the money
cant beat a good blowout.
The spacers are a good idea if you are supercharging an MPI or somthing and want to be able to change it to standard if you flog it, but as above it will be just as cheap to get the chambers enlarged,
also if you have to pull the head in the future it'll be 20 quid a time rather than a tenner!!
plus with the spacers you loose squish (que Vegard lol)
captain_cabinet
Member #: 1901
Bolton
If only I had known at the time! *oh well*
Well as soon as I can afford to I will look at getting the work done to the head and getting rid of the spacer.
Chris
To be fair, I know of a lot of VW people that use these to good effect.
Alex .. I'm sure they do, but A series head gaskets aren't exactly bullet proof in standard form!
in principle if you don't got stilly with the boost, I don't see a problem with it.
evolotion
Member #: 83
Glasgow, Scotland
there isnt a problem with it if you dont go silly wiht boost and your ignition timing is perfect, but the facr is that the a- series head leand itself well to being opened out to lower the CR without bodges like decompression shimms. i have to run a decompression shim (s) and i have had my fair share of failures when pushing the limits. on an A the option of openin gout the head is right there infront of you, making decompression shims a very lazy mans bodge.
Denis O'Brien.
johnK
Member #: 690
Norfolk
Gav - how much cc do you need? - you can get A gaskets with 12cc in them
JK
If Carling made Mini engines
Gavin Wakely
Member #: 793
Well John all I know is the engine is 1293 and as far as I know the head and and deck hight are standard. I was probably looking at 15psi with the charge cooler system.
JK
johnK
Member #: 690
Norfolk
Gav - do you know what piston dish you have - and is the head "n/a" style?
Gavin Wakely
Member #: 793
Don't know pistons until engine comes out in about a month, and head is a standard turbo.
