| Home > General Chat > Inlet manifold question..? | |||||||
784 Posts Member #: 912 Post Whore North Yorkshire |
4th Jun, 2008 at 10:34:56am
Just need to know what to use with regards to using a mirage set-up.
I drill holes in everything..! |
4th Jun, 2008 at 12:07:16pm
Sorry, :$
4th Jun, 2008 at 12:18:27pm
You can use either. I prefer the turbo one, but one of the fastest roadgoing turbo minis in th world uses the N/A one iirc. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
4th Jun, 2008 at 12:44:48pm
Thanks Wil_h
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
4th Jun, 2008 at 01:45:32pm
I think they are both good for flow, but one is deeper than the other so needs special washers. I could be way off though... where's nic? |
4th Jun, 2008 at 05:53:20pm
If you use the turbo one you will need to make the flanges thinner so that they match up with the mirage ones.
4th Jun, 2008 at 05:59:09pm
yup, i use the turbo one, just thin down the flanges. fairly straight forward but takes a while.
4th Jun, 2008 at 06:26:14pm
ive got a regular mg mutro one as wil said |
4th Jun, 2008 at 06:45:17pm
4th Jun, 2008 at 07:27:29pm
When you say thin the flange, do you mean maching the manifold face or just grind a bit off where the nut and washer bolt up to? On 7th Nov, 2008 Nic said:
4th Jun, 2008 at 07:32:36pm
On 4th Jun, 2008 Jay#2 said:
When you say thin the flange, do you mean maching the manifold face or just grind a bit off where the nut and washer bolt up to? Thin it down from the nut side. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
4th Jun, 2008 at 10:42:23pm
This is the best pic I could find of mine (using metro turbo manifold) but you can just about see enough to get an idea.
4th Jun, 2008 at 10:51:31pm
Ah yes, I was thinking about machining the face as I get the benifit of moving everything closer to the head and maybe gaining a few extra mm clearance between plemum and bulkhead. I have a central speedo and even with the angle drive on the speedo cable it's getting mighty tight! On 7th Nov, 2008 Nic said:
4th Jun, 2008 at 10:52:01pm
5th Jun, 2008 at 08:43:47am
Cheers for the info guy's.
5th Jun, 2008 at 06:34:52pm
