| Home > General Chat > Spot welder s/h cost? | |||||||
4th Jun, 2008 at 06:48:27pm
I've found for sale locally a Sealey spot welder, it apparently hasn't had much use, but is a few years old. It does come with a selection of different electrodes. It is an older type, the newer ones I've seen are all contained in the bit you hold, but this has a seperate box that contains the timer, and the welding bit plugs into that.
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
4th Jun, 2008 at 06:50:32pm
Tom my advice would be to try before you buy, just because its old dont mean its whick :) take a selection of thickness metal and have a crack Edited by Richie on 4th Jun, 2008.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
4th Jun, 2008 at 06:51:28pm
1391 Posts Member #: 1686 Post Whore Oxford |
4th Jun, 2008 at 08:23:34pm
give it ago. they work quite well.
OMG Robert that's a big one |
4th Jun, 2008 at 08:43:16pm
id be a little concerned why its so cheap considering the hand held ones are 200 quid. On 19th Feb, 2011 Miniwilliams said:
4th Jun, 2008 at 09:18:06pm
if it works thats a good price, I was looking at them about a year ago and they were going for at least 150 S/H for basic ones.
4th Jun, 2008 at 10:27:51pm
tom i have one that i never use, you are more than welcome to grab it this weekend and hang on to it as long as you like Crystal Sound Audio said:
4th Jun, 2008 at 10:31:41pm
Cheers guys, well I'm off to have a look at it tomorrow night so I'll take a couple of bits of plate and see what is what.
4th Jun, 2008 at 10:57:32pm
thats a good price if it is working properly, particularly if it has extra electrodes with it as well. You might need to put a 16amp socket into the garage for it though depending on the loads |
4th Jun, 2008 at 11:07:04pm
5th Jun, 2008 at 09:15:25am
I have a handheld (SIP, had it for years) and I also have to run it on a 30A circuit and it still occasionally trips the RCD.
487 Posts Member #: 1495 Senior Member |
5th Jun, 2008 at 09:41:55am
sounds like a bargain, its the arms that cost. Deffo try b4 u buy though. |
5th Jun, 2008 at 08:29:06pm
On 4th Jun, 2008 wolfie said:
tom i have one that i never use, you are more than welcome to grab it this weekend and hang on to it as long as you like Bugger, missed this reply completely, damn it! Anyway I've just been and bought the one locally, took a couple of bits of 2mm plate and spotted them together, with the reasoning being to see if it would weld through three plates (rear valance) OK. Here is the result
Ended up giving the guy £110 as that was what he wanted with all the arms etc to go with it. I've had a play in the garage when I got back and did 8 spot welds in about 2 mins without tripping anything.
5th Jun, 2008 at 10:00:04pm
If you got a good selection of arms with it for that price, you did very well.
at least you get to see its quality first hand
