| Home > Help Needed / General Tech Chat > Too Low? | |||||||
1050 Posts Member #: 764 Post Whore Staffordshire |
13th Jun, 2008 at 07:08:20pm
I've just done all the suspension on the mini, everything new and adjustable. I would like optimum handling but also like the look of a decked car.
13th Jun, 2008 at 07:18:37pm
Bye Bye ball joints and bearings!!
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
13th Jun, 2008 at 07:36:29pm
I love the look of this, thats it the bmw is going, I want a decked clubby estate!!!
13th Jun, 2008 at 07:55:29pm
i thuink you may just wear a channel in you tyres if you drive it like that on british roads,lol |
13th Jun, 2008 at 07:56:44pm
Looking at it, it's running about the same height as the TT. We run that with the front bottom arms level. Problem is at this height, the top arm is at such an angle that the effective spring rate at the front is very small, so you'll need yellow dots as a minimum.
13th Jun, 2008 at 07:57:20pm
That won't work, you've obviously got no suspension travel. Dangerous and silly. On 13th Jul, 2012 Ben H said:
13th Jun, 2008 at 08:36:39pm
But he will have travel if he addresses the issues raised above. On 7th Nov, 2008 Nic said:
13th Jun, 2008 at 08:40:42pm
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
13th Jun, 2008 at 08:48:10pm
I'm about to set mine up 'low' too. Aiming for about 2" of clearance between the rear tyre and the [steel] arch. Bouncing the car by standing in the boot suggests there will be enough clearance, but it won't be until I run it around a few bends that I'll know whether I'm too low. Front end I just keep hacking back to gain clearance!
![]() 514 Posts Member #: 2169 Post Whore Malta (Ex. Scotland) |
13th Jun, 2008 at 09:48:46pm
Sweet Jesus thats lowwwww!
Warning:Stig in Training
13th Jun, 2008 at 10:54:02pm
haha, can't believe you've left it that low dude. looks pretty with my wheels on On 20th Oct, 2015 Tom Fenton said:
13th Jun, 2008 at 11:14:04pm
looks gorgeous but i think it will be too low unless what has been said above is done. a nice bit of tubbing and choping should make it possible.
14th Jun, 2008 at 10:53:31am
Thanks for the info most apreciated.
On 13th Jun, 2008 wil_h said:
Looking at it, it's running about the same height as the TT. We run that with the front bottom arms level. Problem is at this height, the top arm is at such an angle that the effective spring rate at the front is very small, so you'll need yellow dots as a minimum. Yeah the bottom arms are pretty much horizontal :) only running standard donuts atm, will take a look into yellows. On 13th Jun, 2008 wil_h said:
You also need to check if your ball joints bind. This is easy to check. Remove the shock and doughnut and lift the suspension as high as it'll go. It needs to hit the bumpstop before binding; in my experience, with negative camber, this isn't a problem. nice idea... will do this later... the bump stops are the hydrospasic type that mount to the shock mounting, so should be able you just remove it and cut it down to suit. On 13th Jun, 2008 wil_h said:
And, obviously you need some serious body mods. I don’t mind cutting chunks out the front... I just don’t fancy tubbing the rear. As i have rear bump stops, i assume i can get away with it?? On 13th Jun, 2008 wil_h said:
Finally, at the back, check how close the brake pipe is to the bodywork. I moved mine and put it underneath the radius arm. Already done, i have the minispares single piece braided hose. Replaces the solid and flexy hose. So its tied up neatly round the back. On 13th Jun, 2008 wil_h said:
When I have my new house I'll be hapy to set your car up using my stuff if you need it done, but I obviously live miles away. This goes for anyone. Your not too far tbo, it needs setting up before avon so i guess you wont be moved by then?
Nick said:
haha, can't believe you've left it that low dude. looks pretty with my wheels on nooooo... my wheels now :) Edited by Anton on 14th Jun, 2008. |
14th Jun, 2008 at 11:03:30am
14th Jun, 2008 at 01:32:52pm
Looks awsome!!
![]() 69 Posts Member #: 1163 Advanced Member Malvern, Worcestershire |
17th Jun, 2008 at 12:45:48am
I would say that you should run the fuel lines inside the car. Safest option as it may not look too good after you've taken your fuel lines out by a speed bump.
17th Jun, 2008 at 07:11:24pm
i want to have pritty much level driveshafts, i will be on 10's as well so the car will be very low, i will be fitting a sump gard as well just to save things :) imo that looks awsome :) Drives
17th Jun, 2008 at 07:15:55pm
I've decided not to even try to get mine lower after I took my entire exhaust from the manifold back off, driving up a country lane.
17th Jun, 2008 at 07:17:41pm
i ripped off my old exhuast on a savage speed bump, that was only 4.5" off the floor at the sump or somthing stupid like that, the bottem arms are almost level! Edited by Paul R on 17th Jun, 2008. Drives
