Home > Help Needed / General Tech Chat > tick over not good?
j4m13_turbo
Member #: 2747
Peterborough
Just got my mini turbo running for the first time today...
Tick over isnt very smooth, fine when revving but not on idle *frown*, was wondering if any one could help??
Jamie.
Ric
Member #: 36
Basingstoke
What's wrong with it? Only running on three?
make sure its running on all cylinders
make sure its timed in correctley
then adjust the mixture
a RR is the required to set it up right
shane
Member #: 1246
Lowestoft, Suffolk.
Check evrything to ensure you have a good start point for diagnosis, timing, fueling, valve clearences, and go from there!
Shane
Don't forget to set the fuel pressure!
turbo hogster
Member #: 178
stowmaket suffolk
what cam are you using as this can be lumpy on tick over if its a hottish one.
but still check all the above
j4m13_turbo
Member #: 2747
Peterborough
Cheers guys :), ... its running on all 4 :) erm ive reset the tappets twice ( bit better ) erm, going to check timing, fuel pressure... its not to bad now... it dosnt cut out on tick over its just a bit lumpy ( if you get what i mean )
Cheers guys :)
Jamie.
Ric
Member #: 36
Basingstoke
What do all 4 plugs look like? This could give you a clue as to what is going wrong (lean or rich etc.)
j4m13_turbo
Member #: 2747
Peterborough
Im sorted guys!! :) Cheers for your help *happy*... in the end it was the timing slightly out but its sorted and runs grate now *happy*
Thanks guys!!
*happy*
