| Home > Help Needed / General Tech Chat > Piston Dilemma. | |||||||
17th Jun, 2008 at 06:36:05pm
It's engine rebuild time again. Having not had to remove the engine for the last three, nearly four years now has been great, but it's time to give it a rebuild. It's run a minimum of 10psi but has been running 20psi for the last two.
17th Jun, 2008 at 06:37:35pm
i belive some of the bigger power boys are using MEGA pistons from MS with some high power figures, i belive one is in the 180's whith quite alot of boost Edited by Paul R on 17th Jun, 2008. Drives
17th Jun, 2008 at 06:39:36pm
I'd get it in bits and assess the state of whatever is in there before getting too excited about buying new pistons.
17th Jun, 2008 at 06:40:06pm
Yeah, but wasn't there a problem with them ? Did MS sort it ? |
17th Jun, 2008 at 06:44:29pm
go for OMEGA cast ones phil well proven and around 270 billys
17th Jun, 2008 at 06:51:27pm
i've been using the cast AE ones 21253's for the past 3 or 4 years now and i can't fault them. been running 10psi minimum and 15psi quite often, been up to 20psi a few times with no issues either.
17th Jun, 2008 at 07:12:09pm
what about the ausie hypatec ones ? cheap as chips
18th Jun, 2008 at 09:11:03am
phil as tom says have a look and see what state your bores are in.
19th Jun, 2008 at 02:44:13pm
Im sure a lot of us would donate a pound each to see pics of your sister
19th Jun, 2008 at 09:32:35pm
2 pounds of what nic ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
78 Posts Member #: 1021 Advanced Member Portugal |
31st Aug, 2008 at 08:38:46pm
my dilemma is another
31st Aug, 2008 at 08:45:56pm
i was thinking the same thing the other day aswell. which way would give you better squish? |
31st Aug, 2008 at 08:48:23pm
31st Aug, 2008 at 10:31:12pm
I'd personally go with the bigger dish pistons and be able use a better chamber design in the head. |
1st Sep, 2008 at 08:28:39am
yep thats what i did phil , id run the omega cast , if i was in your situation . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
