Home > Technical Chat > Oil leak from bottom of flywheel housing
johnnysti
Member #: 2480
Hi
Had a look under the car and ive got a slight leak from a hole with a split pin like thing hanging out, at the bottom of the fly wheel cover.
Can anyone tell me what has caused this and what i can do to sort it out?
Thanks
feature=mhum
that orange seal is fuckety fucked
OR, the bushings in the primary gear are fuckety fucked. Most likely Nic's advice.
It is indeed a split pin. Primary gear oil seal could well be leaking, also check the bushes while you're there. Oil leaks are almost a standard thing on a Mini, if it doesn't leak you've got no oil in it!
Get it sorted quickly before it ruins your clutch *wink*
as long as its not leaking from the front of the block im happy! LOL
johnnysti
Member #: 2480
To try and stop this happening again, is there anything 'uprated' i can get when i replace it?
feature=mhum
You could try the black MPI seal, and if not fitted, you can get a plastic cover that fits over the primary gear spline.
This seal is a pain to fit by the way. After buggering up two seals last time I tried I was advised to slide the primary gear out and fit the seal to this first. then knock it into the housing. It worked for me.
Andy500
Member #: 2443
Cheshire
Minispares sell an uprated seal if you check on there website you will see it. Oil leaks are not a standard on a mini although they are common due to the design of things etc but theres no reason for oil to be leaking unless something is incorrect/knackered. It certainly sounds like the crank/clutch oil seal is knackered and the only way to sort it is to get the flywheel and clutch assembly off and then replace it. May be worth checking that all the breathers are nice and clear and not allowing excessive crankcase pressure to build up before you start removing things though
alpa
Member #: 2093
Grenoble, France
Not sure these seals were designed to resist to the crank under boost. Mine is new and leaks even with 200mbar boost. Never had that before on two NA Minis.
As said before the best is probably to make a good crank ventilation.
Edited by alpa on 27th Jun, 2008.
El Potter
Member #: 2169
Malta (Ex. Scotland)
How will it fuck up your clutch Gav?
My daily leaks from there, but I don't want to have to do anything more to it,cos I'm sick and tired of it.
Warning:Stig in Training
stefaz
Member #: 1656
stoke-on-trent
if oil is getting inside the clutch housing (through that seal) it can get on the clutch and ruin the friction plate material
minis run dry clutches, that seal is to keep them that way!
El Potter
Member #: 2169
Right
Well you know what they say:
If it ain't broke don't fix it*happy*
When the flywheel oil seal is leaking it is more a case of "If it ain't broke it will be soon"
El Potter
Member #: 2169
You might have a point Tom.
Bollox.More work on the bloody daily:(
At this rate I'll have to push the TM out the garage with the aid of a walking stick*happy*
