Home > Help Needed / General Tech Chat > cooling
philc
Member #: 1346
bromsgrove
I am sure this isn't right, my temp gauge showing the needle just above the blue line, i am sure this is not the optimum running temp. I have a thermostat in (not sure which one though) two core rad and 4 blade fan. Two things i suppose change the thermostat and or change the 2 core rad to a standard rad. Any thoughts?
So, at what temp is the blue line? You need to get a proper gauge.
Edited by Vegard on 31st Jul, 2008.
greymini78
Member #: 2408
surrey / ewell area.
Mine is running at about 180 to 190 f
tomf
Member #: 1746
Kent
Mine rund very sligtly above the middle marker... Is that correct is it it running to hot?
Depends on what the middle marker is temperaturewise, but often the middle is OK *wink*
You need to find out if the engine is actually at the right temp and the guage is wrong or vice versa
I used to have overheating problems-i fitted a capillary gauge and they were miraculously fixed
philc
Member #: 1346
bromsgrove
how do i do that then
Same here, I magically fixed my over heating problem by fitting a Race Tech gauge.
Buy a good gauge as mentioned above, or borrow one of those infra red temp guns and measure the head temp with that *wink*
For what a gauge would cost it's worth it to protect your engine, you need to be able to believe what your instruments tell you.
