Home > Help Needed / General Tech Chat > K1100 N/A and Servo
Has anyone done a normally asperated k1100 and kept the servo? If so where did you take the vacum feed from?
Jimbo
johnK
Member #: 690
Norfolk
Jim - I don't think you'll get enough vac off the ITB's even if you join all the vac points together - get him to ditch the servo!
If Carling made Mini engines
nutter driver
Member #: 47
Not very sunny swanage
or use a vacuum pump off a diesel of some sort?
Bin the servo and save some weight *tongue*
fooking servo, you week kneed faggot,
nbooth660
Member #: 1234
I have strong knees and don't like faggots.... and I have a K headed A-series with a servo. I did as John described above and t'ed together the TB's. It appears to pull enough vacuum from the limited runs I have done.
I think the trick is to get the one way valve as close to the servo as possible to help maintain the vac in the servo.
Nick.
What about using a plenum and single throttle body as you would with a turbo setup?
You'll have a whole plenum of vacuum to use*wink*
tadge44
Member #: 2500
Buckinghamshire
Or fit a vacuum tank to store what little vacuum you can pull, so that there is always some there when you need it.
So, are you a homophobe?
nbooth660
Member #: 1234
I'm a Faggotphobe:)
Ingredients for faggots
pigs liver 450 gm
onions 2 pc
breadcrumbs 100 gm
suet 75 gm
chopped sage 2 tsp
salt sq
pepper sq
The servo has a built in resevoir (*sp)
nbooth660
Member #: 1234
Exactly. The vacuum has a built in reservoir and you use a one way valve to keep it there and therefore you don't rely on the vacuum at any given time.
It works on mine....
Nick.
removed the servo now.
*Clapping*
