| Home > Help Needed / General Tech Chat > airlock troubles | |||||||
5th Aug, 2008 at 04:43:22pm
as you may have seen in the show us yours section I am finishing a K headed engine.
5th Aug, 2008 at 05:00:42pm
Have you tried opening and bleeding at every point possible, witht the pump running? |
5th Aug, 2008 at 07:01:23pm
if you can acess the pump release the jubilee clip and poke a screw driver in along side the pipe on the inlet side of the pump feed some water in from the expantion tank with the pump runing this has worked well for me on the racers with no real problams.
On 17th Feb, 2009 Rob H said:
5th Aug, 2008 at 07:54:59pm
hmm, would that not just introduce more air as air would leak in by the screw driver? |
5th Aug, 2008 at 08:48:01pm
do what has been said but at the highest point possible! |
5th Aug, 2008 at 09:08:56pm
no gravity will do its work an force the water out air will be forced out by the gravity,
5th Aug, 2008 at 11:18:19pm
Vac it down
6th Aug, 2008 at 06:31:30am
You need to get the expansion tank tee'd into the suction leg of the pump. By doing this you are introducing a head of water to the suction side of the pump, and it will work a treat.
6th Aug, 2008 at 07:16:16am
6th Aug, 2008 at 10:54:37am
I have a bleed pipe running from my head outlet pipe going straight to the expansion tank, works really well!
