Home > General Chat > Painting wheels
I've just bought some Minilites and I'd like to paint them black.
They are brand new with lots of clearcoat.
What do I need before I paint them? Rub them down, matte them down?
Anyone?
mokle
Member #: 2488
Edinburgh
I would of thought just rub them over with wet and dry to give the new paint a key to stick to.
Tony
Richie
Member #: 628
i stripped mine back to bare metal then painted em. I used a mild paint stripper to do the job, then finished off with fine wet and dry to make sure i had all the chav / chemical off the metal mine seem to have worked ok
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
I'd prefer leaving the primer on... ??
Richie
Member #: 628
erm then as per Mokle buddy, just make sure you give em a good key with summit like 600 grit then clean the surface with alcohol / similar to get rid of any grease etc etc
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
I'd do the same and just key them and possibly dust some primer on before the black, just incase the black doesnt take to the keyed laquer.
Build Thread Click Here
V, What sort of paint have you got for them?
Rick
clubminiflip
Member #: 54
nr coventry
key them up with scotchbrite pads, a medium grade pad of fine grade will be ok, then a wipe with panal wipe, or thinners, if you wipe them with thinners leave them 10 mins before a quick dust with primer then paint them, if painting them with cans use red-oxide primer for black paint, seems to get a better deeper black with that, or white primer for silver/mettalics, grey for normal colours red/blue/green etc
when painted & dry, use an ultra fine scotchbrite pad on them all over, then laquer them, dust laquer on in thin layers, dont be tempted by a all over wet look or it'll run! tin dust coats every 60secs, 3 cotes should be enough, leave for two weeks then t-cut& polish them
& take the tyres off for a proper job if not let the air out & break the bead on the face side of the rimto mask them "right"
or the quick getto method, wash them then paint them matt black & it makes the tyre look good too! *happy*
2pck paint is ace on rims or anything else, i know the health & saftey representatives say you should'nt use it but it wont kill ya if ya paint them outside, 2pac gos off quick too which is a bonus
if not 2pack then rattle cans & laquer, plasticote laquer is decent
Edited by clubminiflip on 6th Aug, 2008.
Wheelpaint in a can.. I've used it previously on some wheels I beadblasted to bare aluminium, then etch primed. Seemed to work fine.
Just a good key up then, grey scotch/ 800 wet or dry.
Make sure its a nice warm dry place.
Rick
