Home > Show Us Yours! > few pix of my car
turbominij
Member #: 2104
Essex - UK
few pix of my car
1293 turbo
T2 on a mirage manifold
Edited by turbominij on 22nd Aug, 2008.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
nice!
Get that intercooler up front though
turbominij
Member #: 2104
Essex - UK
yer everyone keeps saying that im trying to keep it all hidden:)
ps thanks for the Plenum chamber by the way nic
looks nice matey
Gavin Wakely
Member #: 793
Nice work, looks very tidy 8-)
miniallsort
Member #: 1131
wow mint
turbominij
Member #: 2104
Essex - UK
update on my car *frown* not good unfortunatly *frown*
the engine came out saturday for a leaking manifold gaskit. which i thought fair enought a bit of a pain but i can cope with that.
once the engine was out took apart all the turbo assembily and was cleaning manifold faces and my friend was looking over the turbo and found a big crack in the wastgate.
the crack runs from the outside edge to the wastgate port and then from the other edge of the wastgate port to the impeller port and is right the way through the casting.
so the car is off the road till i can arrange a replacement exhaust casing or replacement t2 turbo
Ben H
Member #: 184
Melton Mowbray, Pie Country
Have you got any photos, I am not sure I have seen a T2 without a crack, it may be OK.
http://www.twin-turbo.co.uk
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Both of mine have cracks thats for sure.
On 7th Nov, 2008 Nic said:
naeJ
m
Carl
Member #: 95
liverpool-on-sea
nice car!
why did you take engine out to change manifold gasket?
Edited by Carl on 23rd Nov, 2008.
turbominij
Member #: 2104
Essex - UK
i dont have any pix at the mo getting some sorted will post up soon
everything is so tight that it is impossible to do it with the engine in there as the bulk head is not cut because i am running a t2 on mirage manifolds if did not need to.
you can just get your little finger between the turbo and the body work
crickey, could you not have double nutted the haed studs, and slide the head forward and off?
i guess it would mean a new hg, but id pay that not to have to lug the lump out!
turbominij
Member #: 2104
Essex - UK
i dont have a problem taking the engine out it dont take much i dont think. i can have it out and back in in a day if all goes well (done it before when found a water leak on the back nut on the turbo!!!)
This time however i found this crack so stopped till i can get it checked out was on track for out and in, in a day as well sods law that is
turbominij
Member #: 2104
Essex - UK
i have got some pix but thay arnt the best im afraid i have highlited them on 2 of the pix
turbominij
Member #: 2104
Essex - UK
Edited by turbominij on 23rd Nov, 2008.
ERA ANT
Member #: 4179
Cumbria
looks a nice clean tidy car mate. shame about the turbo like.
Do it right the first time and make it mint!!!!!!
turbominij
Member #: 2104
Essex - UK
i have made a new therd thought it was better than carrying on here
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=256495
