Home > Wanted > Turbo dizzy
ade
Member #: 3662
Just need one that will run a near standard turbo engine, preferably with electronic ignition.. i think one with the number 42628 is what im looking for..
thanks
Welcome to TM :)
Turbo Phil has just put one on ebay.
See the Ebay links subforum, below this one *wink*
Cheers Bat ! *happy*
I do have another one as well, but one of the screw holes to hold the dizzy cap on is threaded. Apart from that it seems fine to use if you could fix that ? Tap it out & use a larger screw ?
Mine was threaded as well.
But I just tapped it as Phil says and used a couple of allen headed bolts. You will need to open up the holes in the cap as well.
Easy peasy.
ade
Member #: 3662
cheers guys, ive made a bid on the ebay one, hopefully i win cos ive been after one for months... if i dont, how much do you want for the one that needs tapping?
