Home > Help Needed / General Tech Chat > Gt turbo
Giancooper
Member #: 2402
what you think about put the r5 carb on a mini turbo?
Is 32 against the 44 of the hiff....
I've alot of this carb.... and for me is easy tune it......
Edited by Giancooper on 27th Aug, 2008.
Giancooper
Member #: 2402
maybe I can use it.......
Use what you can get easily, if the SU is unavailable *wink*
What out for the float, brass ones collapse under boost
Giancooper
Member #: 2402
But if I use the r5 carb, can I have the same hp of the Hiff?
i should of thought so
Do the 300bhp 5's use it still?
Star Mag
Member #: 375
Leicestershire
I was having this disscussion with one of the lads a while back! They are a easy carb to tune and they make good power on the renaults, The fastest C1J engined 5 still uses one and that runs a quick 1/4. However the su is also fairly simple to tune so dont see the point unless you have a problem picking one up?
Giancooper
Member #: 2402
because I have one hiff n/a turbed, but when i start the engine the fuel don't go from the float (this is full of fuel) to the needle tube(sorry but I don't the name in english)
I hace the metro plenum and the turbo fuel regulatore...
someone can help me?
Edited by Giancooper on 28th Aug, 2008.
