Home > Beginners Tech > Bolt & Screw List for A+ Engine & Box
codd_coupe
Member #: 1772
Leicestersheershire
Does anyone have a list of all the nuts, bolts and screws needed on an A+ Engine and Gearbox?
I'm starting to put the engine back together and have decided to replace all the fixings on it at the same time.
I know there used to be a list on minifinity, before they lost there server. Did anyone copy the list from there, or have one of their own?
*smiley*
Tim Rowe
"Is est totus perfectus per fumi quod speculum"
GTM Coupe Turbo
Moss Catalog?
it is on here somewhere
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=144176
codd_coupe
Member #: 1772
Leicestersheershire
Cheers Joey, I thought someone had to have saved it somewhere.
Now I can go and pester my local nut and bolt man!!
Tim Rowe
GTM Coupe Turbo
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Damn handy link, cheers
On 19th Jan, 2010 wil_h said:
chinlesswonder
Member #: 1192
In the garage......again!!
this is as much as i have.
Sub Assemby Location Type Size Thread Length Qty Required
Gearbox Diff Housing Setscrew 5/16” UNC 1" 10
Gearbox Diff Housing Spring Washers 5/16” - - 13
Gearbox Diff Housing Full Nuts 3/8” UNF - 4
Gearbox Diff Housing Full Nuts 5/16” UNF - 4
Gearbox Diff Housing Spring Washers 3/8” - - 4
Doors Mini ClubmanVan Rear Door Hinge Hex Bolts 1/4" UNF 1 3/4" 8
Doors Mini ClubmanVan Rear Door Hinge Hex Bolts 1/4" UNF 3/4" 8
Doors Mini ClubmanVan Rear Door Hinge Nyloc Nuts 1/4" UNF - 16
Head Mini Heater Hose Take Off Spring Washers 1/4" UNF - 2
Head Mini Heater Hose Take Off Full Nuts 1/4" UNF - 2
Engine Engine Mount Setscrew 5/16” UNF 1" 7
Engine Engine Mount Setscrew 5/16” UNC 1" 3
Engine Engine Mount Spring Washers 5/16” - - 10
Engine Engine Mount Full Nuts 5/16” UNF - 4
Rear Subframe Rear Subframe Mounting (Mk3 onwards) Hex Bolts 5/16” UNF 2 1/2" 6
Rear Subframe Rear Subframe Mounting (Mk3 onwards) Hex Bolts 5/16” UNF 1 1/2" 2
Rear Subframe Rear Subframe Mounting (Mk3 onwards) Nyloc Nuts 5/16” UNF - 4
Engine Flywheel Cover Setscrew 5/16” UNC 1" 8
Engine Flywheel Cover Spring Washers 5/16” UNC - 8
Head Manifold Full Nuts 5/16” UNF - 6
Head Manifold Thick Washer 5/16” - - 4
Head Manifold Flat Washer 5/16” - - 2
Steering Steering Rack U-Mounting Nyloc Nuts 5/16” UNF - 4
Engine Timing Cover Setscrew 5/16” UNF 3/4" 5
Engine Timing Cover Setscrew 1/4" UNF 7/16" 6
Engine Timing Cover Flat Washer 5/16” - - 5
Engine Timing Cover Spring Washers 5/16” - - 5
Engine Timing Cover Flat Washer 1/4" - - 6
Engine Timing Cover Spring Washers 1/4" - - 6
Engine Timing Cover Full Nuts 5/16” UNF 1
Engine Timing Cover Full Nuts 1/4" UNF 1
Head Heater Hose Take Off Setscrew 1/4" UNF 1/2" 2
Head Heater Hose Take Off Flat Washer 1/4" - - 2
Engine Radiator Top Setscrew 1/4" UNF 1 1/2" 2
Engine Radiator Top Flat Washer 1/4" - - 2
Engine Water Pump Setscrew 5/16” UNF 1" 2
Engine Water Pump Hex Bolts 5/16” UNF 2" 2
Engine Water Pump Flat Washer 5/16” - - 4
Engine Water Pump Spring Washers 5/16” - - 4
Head Thermostat Housing (Short type) Hex Bolts 5/16” UNF 1 1/2" 3
Head Thermostat Housing (Short type) Flat Washer 5/16” - - 3
Electrical Alternator Top Setscrew 5/16” UNF 2" 2
Electrical Alternator Bottom Setscrew M8 1.25 20 1
Electrical Alternator Bottom Nyloc Nuts M8 1.25 - 1
Electrical Alternator Flat Washer 5/16” - - 4
Electrical Alternator Spring Washers 5/16” - - 4
Electrical Alternator Full Nuts 5/16” UNF 1 1/4" 2
Electrical Starter Motor Setscrew 3/8” UNC 1 1/4" 2
Electrical Starter Motor Spring Washers 3/8” - - 2
Electrical Dizzy Mounting Setscrew 5/16” UNF 3/4" 1
Engine Tappet Chest (Small Bore and Cooper S) Setscrew 5/16” UNF 1 1/14" 2
Engine Tappet Chest (Small Bore and Cooper S) Flat Washer 5/16” - - 2
Engine Mechanical Fuel Pump Setscrew 5/16” UNF 1 1/2" 2
Engine Mechanical Fuel Pump Flat Washer 5/16” - - 2
Engine Mechanical Fuel Pump Spring Washers 5/16” - - 2
Engine Oil Filter Housing Setscrew 3/8” UNC 1" 2
Engine Oil Filter Housing Flat Washer 3/8” - - 2
Engine Oil Filter Housing Spring Washers 3/8” - - 2
Head Head Mounting Full Nuts 3/8” UNC - 9
Head Head Mounting Flat Washer 3/8” - - 9
Suspention Ball Joints Full Nuts 7/16" UNF - 4
Suspention Ball Joints Spring Washers 7/16" - - 4
Engine Main Oil Feed Banjo Bolt 5/8" UNF - 1
Head Rockers Mountings Full Nuts 5/8" UNF - 4
Head Rockers Mountings Flat Washer - - - 4
Suspention Lower Arm Support Pin Full Nuts 3/8" UNF - 2
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
Anton
Member #: 764
Staffordshire
this is the list i have
T-shirt
Member #: 2461
Portsmouth
Does anyone know whether this list has been expanded at all?
