| Home > Help Needed / General Tech Chat > MPI Blocks | |||||||
3rd Sep, 2008 at 10:51:57am
what are the known pro's and cons of using an mpi block? Crystal Sound Audio said:
3rd Sep, 2008 at 01:17:23pm
Oil drips down the front when changing the filter?
238 Posts Member #: 1649 Senior Member West Sussex - dreaming of forced induction! |
3rd Sep, 2008 at 01:22:26pm
Cons: Pain in the chuff to mount an alternator if your not using the standard brackets and alternator (unless you are good at fabricating stuff)
3rd Sep, 2008 at 01:22:46pm
Heavier than an A+ block
3rd Sep, 2008 at 01:26:23pm
Oh and you cannot use one of those oil pressure adjusting thingymabobs, but thats not really a tradgedy as there are shite anyway.
3rd Sep, 2008 at 01:29:17pm
Quite alot of them have liners so no over bore :( well a max of +0.040 On 17th Feb, 2009 Rob H said:
3rd Sep, 2008 at 01:35:58pm
Oil cooler? On 13th Jul, 2012 Ben H said:
3rd Sep, 2008 at 03:36:08pm
On 3rd Sep, 2008 Vegard said:
Oil cooler? Hi, A sandwich plate would sort that out, mmm sandwiches
Cheers, Gavin :) VEMs Authorised Installer / Re-seller. K head kits now available!
3rd Sep, 2008 at 06:39:02pm
I've seen them used on the miglias, no problems there. Team www.sheepspeed.com Racing
3rd Sep, 2008 at 06:48:47pm
4th Sep, 2008 at 08:05:03am
On 3rd Sep, 2008 Sprocket said:
Whats wrong with liners ![]() I agree. Liners are great! On 13th Jul, 2012 Ben H said:
4th Sep, 2008 at 08:17:03am
except they limit the amount you can overbore. On 28th Aug, 2011 Kean said:
4th Sep, 2008 at 08:18:21am
why cant you just bore the old liner away and put in new ones which are larger? |
1391 Posts Member #: 1686 Post Whore Oxford |
4th Sep, 2008 at 02:13:38pm
i presume because they would have to be a certain thickness and that you would have to bore out so big to put the bigger liners in it would be close to oil ways and water ways ect. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
4th Sep, 2008 at 05:36:31pm
On 4th Sep, 2008 Sam said:
i presume because they would have to be a certain thickness and that you would have to bore out so big to put the bigger liners in it would be close to oil ways and water ways ect. Erm, NO. On 13th Jul, 2012 Ben H said:
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
4th Sep, 2008 at 10:33:34pm
Can the turbo crank be fitted to an mpi block?
4th Sep, 2008 at 10:33:43pm
**SORRY**
Edited by shane on 4th Sep, 2008. |
4th Sep, 2008 at 10:49:40pm
If you have an MPI engine, be easier just to do the business with the crank thats fitted. :)
On 4th Sep, 2008 shane said:
Can the turbo crank be fitted to an mpi block? Shane On 19th Jan, 2010 wil_h said:
