Home > Technical Chat > straight cut gear wear
ashley_dude00
Member #: 1751
chichester/bognor
wondering if people knew how many miles straight cut gears should last,iv herad there a lot more wearing.help would be appreciated
On 30th Aug, 2008 Richie said:
too much my wife says "not that friggin site again" so i pull my pants back up and turn it over to TM. *wink* iam on pretty much every day as i lead a sad existance
ministef1
Member #: 1791
Cranleigh, surrey
stu gurr told me 15000 miles.
"Cars are a lifetime of pain"
ashley_dude00
Member #: 1751
chichester/bognor
is that a safe milage??or before theyr on the limit
turboestate
Member #: 362
durham area
Well from experience mines have being in a turbo motor and now my 1380 16v and have covered 20,000 miles being rebuilt with new bearings at 15,000 there was no visual wear to be seen and sound no different now to when i installed them.
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
i belive someone on here changed theirs at 80000miles.
No hard/fast answer here. You can't say 15K miles, you can't say 8K. Turbo engine torque is way outside of where the original gears were designed, so qualifying 'life' is not easy as the duty cycle is scewed dis-proportionally.
Another example: I changed my Tran-x laygear after 3000 miles as I considered it worn. Others would have run it happily or sold it on ebay as 'perfect'.
my thoughts are the same as daves
good oil nothing less! .... changed regular.
and nothing less than 15/40w grade!
forget the 0/5w super piss oils
ashley_dude00
Member #: 1751
chichester/bognor
cheers looking forward gettin that straightcut whine?what oils do you boys use.make etc??
Millers CVT? is designed for g/box in sump setups, so should be the best, it's not cheap though *surprised*
Turbo Shed
Member #: 30
Epsom, Surrey
i had my JK box rebuilt after about 10,000 miles, i had a piston problem so the box was off, noticed some wear so it had a partial rebuild. i always use good quality 20/50 and change it every 2,000 miles.
with a mini box, driving it till it blows is expensive! i work on checking the box at 10 to 15 thou miles and expect it to need some work
It depends entirely how they are used.
I probably ran my Tran-X set daily driver for about 50k. I had to replace 2nd gear once as I broke some teeth off. But the others were fine.
I think I also replaced 1st and reverse once after my original 4 pin diff broke and sent the pin through them.
Dont forget, if you drive a lot of miles in 4th.....no, or virtually no gear wear should occur on 1-3
If its a rally car or similar...then I'd expect the gears to wear a lot faster given the usage.
Hedgemonkey
Member #: 360
My challenge box wore first seriously. I'd say that the ones I've seen in bits have the first gear on the laygear worn. I think they really start going once you get through the case hardening.
Looking at the rest, I think that if you use a good oil and avoid being too silly in first, it'll last fine.
I wonder what steel they are made out of.........
