| Home > Help Needed / General Tech Chat > Oil t piece | |||||||
22nd Sep, 2008 at 12:20:11pm
Hello, currently i have my oil pressure switch in the turbo feed t-piece but i want to run an oil pressure gauge as well, just wondering how other people have done it? Thanks |
22nd Sep, 2008 at 12:34:26pm
I drilled an taped another hole in the t peice,
559 Posts Member #: 2775 Post Whore Aberdeen |
22nd Sep, 2008 at 12:47:50pm
I used one of the sandwich plates on the oil filter that someone else on here recommended a while back |
22nd Sep, 2008 at 12:54:46pm
Me too, they make life much easier!
On 22nd Sep, 2008 lockfast said:
I used one of the sandwich plates on the oil filter that someone else on here recommended a while back 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
22nd Sep, 2008 at 12:57:11pm
On my oil feed the feed to the turbo is off a banjo fitting, with a male that sticks through it. Then the T piece screws onto this, leaving one port for gauge and one port for switch.
22nd Sep, 2008 at 01:14:18pm
Cheers guys, any links for the sandwich plate? Ta |
22nd Sep, 2008 at 01:25:57pm
17 Posts Member #: 3513 Member Stafford |
22nd Sep, 2008 at 04:05:05pm
I always take the oil feed for the turbo from the top of the filter head - drill, tap and screw in a male quick release coupling - attach the female to the turbo pipe - fresh filtered oil! (never cooked the turbo bearings in 5 years of racing!) Use the block take-off for the pressure gauge and add a T-piece if you want a light as well. Philtune. |
22nd Sep, 2008 at 04:21:26pm
Also on another note, my fuel pump runs off the oil pressure switch (metro), therefore i don't have a light, how do you get round this? run 2 switches? i cant tap into the metro switch as the light would be on all the time i have pressure. Thanks |
24th Sep, 2008 at 12:52:08pm
I took my car to Beechgrove engineering where it got measured up for the braided turbo feed pipe and a braided oil pressure gauge sence line got all the fittings and seals with the unions of my choice.
Own the day
24th Sep, 2008 at 04:38:52pm
Just found the perfect solution :) |
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
24th Sep, 2008 at 04:49:07pm
tell us what it is then because at the moment i am going to be using 2 t pieces and it is going to look pap. |
