Home > Help Needed / General Tech Chat > modifying an intercooler
minimatt
Member #: 2417
hey, this might be a completly ridduclas question, but basically ive got an old intercooler laying a round and i was wondering if i was to remove one of the end tanks, what is stopping me from reducing the size of the core and rewelding the end tank back on is this something that is possible ?
You can cut an intercooler ALONG the core, but not across it.
Makes sense once the end tank is cut off tbh, but you'll need to cut off both end tanks, shorten it, modify the end tanks, then weld them back on.
minimatt
Member #: 2417
so i can cut it from top to bottom as in the direction of the fins ?
Yes.
minimatt
Member #: 2417
cheers guys
No.
As Tom said, you can cut along the direction of flow not across it.
If you cut across the direction of flow, you then have a mammoth task of welding all the flow tube into the end plate.
minimatt
Member #: 2417
ok but wat would be the point of cutting along the core ? as in what would this achive ?
It will make it smaller. Was this not the point of this thread to start with?
Depends if you have a long thin intercooler or a short fat one. Also whether you are shortening it or reducing the height. They come in many different shapes and sizes.
Paul has it spot on here. Trying to weld the flow tubes into the end plate is just not possible, or at least I wouldn't think it was possible anyhow.
No.
Yes but the fins run top to bottom paul.
Thats bollock without referencing the air flow.
The original question was -
The correct answer is "no".
If the original question was "can I cut it from top to bottom in the direction of the tubes" then the correct answer would have been "yes".
Edited by Tom Fenton on 22nd Sep, 2008.
I know what he meant!
Pics with arrows please!
Not that one of you in your prison uniform! *hehe!*
J99UNK
Member #: 9469
letchworth herts
What's the best way to remove any metal swarf from the intercooler when the end tanks have been cut of and modified.( I'm using a cossie intercooler )
hose pipe and lots of washing up liquid.
