| Home > Technical Chat > Question re Turbo Crank Machining | |||||||
128 Posts Member #: 970 Advanced Member Bahrain |
2nd Oct, 2008 at 10:13:29am
Hi, quick question please...
2nd Oct, 2008 at 10:26:21am
When you harden a steel component its only the outer surface and its only hardened down a few thousanths of an inch this allows the component to be strong and hard ratheer than hard and brittle! How much was taken off when it was ground and how big are the journals now?
Own the day
2nd Oct, 2008 at 11:18:30am
Thanks for the info..
2nd Oct, 2008 at 11:24:43am
is the crank a cam6581 or a cam6232? Team www.sheepspeed.com Racing
2nd Oct, 2008 at 11:36:54am
He machined the casting number off |
![]() 673 Posts Member #: 1395 Post Whore chepstow |
2nd Oct, 2008 at 12:29:01pm
Only the early metro turbo crank is different the other ones are just a standard crank IIRC |
2nd Oct, 2008 at 01:37:25pm
The later 6581 cranks are definately 'harder wearing' than all the earlier 6232 cranks. I think it's BS that the earlier cranks were hardedned... On 17th Nov, 2014 Tom Fenton said:
2nd Oct, 2008 at 01:44:15pm
Anyone who has worked the two different cranks would know, as surely if the 6581 been toughned in anyway the machinist would know?
2nd Oct, 2008 at 01:50:27pm
Is there anyway to tell the difference between the two without the numbers.
2nd Oct, 2008 at 01:56:05pm
Oh and is it possible to cross drill one of the hardened cranks?
2nd Oct, 2008 at 04:04:23pm
Take a look at these two threads
Own the day
2nd Oct, 2008 at 05:02:45pm
if its been hardened a the file test is a good starting point, run one over it and see what happens, if its un treated the file will remove material if its hardened it wont mark it as such, also look inside the threads at either end , are they dull in colour or not,is the damper end dull or shiney,
2nd Oct, 2008 at 05:28:31pm
Thanks Joshua... I've read those threads already.
2nd Oct, 2008 at 05:31:43pm
Carl.. I just read your post after my reply. Yes looking to the countersink it is not shiney like the picture of the spigot.
2nd Oct, 2008 at 06:34:50pm
it'll be too hard to do anything to other than by grinding.
2nd Oct, 2008 at 07:01:47pm
Its had a regrind. The journals dont seem very hard anymore as they can be marked quite easily. Should it be rehardened after a regrind?
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
2nd Oct, 2008 at 08:49:39pm
If you take an early crank and a later one, assuming the journals are the same and they are unwedged and "ding" them. Are the dings the same?
Bugger off, I'm getting there. |
2nd Oct, 2008 at 09:25:22pm
On 2nd Oct, 2008 Tareq said:
Its had a regrind. The journals dont seem very hard anymore as they can be marked quite easily. Should it be rehardened after a regrind? What sort of rpm would this crank hold with a set of arrow or sc rods? Cheers Tareq if the tuftriding has been done properly it possible to acheive up to 0.020" depth. which would meen that even after another grind there would still be some toughness on the remaining journals. i once run an un hardened crank for one season in hillclimbing. i used the A series mains, the ones with the oil groove both parts, wedged , knifedge, balanced , but not crossdrilled. ran up to 9k every opertunity when competing after on season, the mains had visual wear and could be felt with finger nails, the high ring that was the croove in the shells, worn down either side, i did my best to linish / polish out the ridge, [ maybe 0,005"] at a guess, but could still see it after a going over, i then had the crank hardened and reused it for another 10 years using the pain A plus bearing in the cap, ,and i still have it on the shelf somewhere , as i only replaced it as the tail had been repaired twice and i decided it was past its best but retained it for an eemergency spare. seing as your so far away tereq, i say just use them and see how they get on, have you any where that can check if it has been balanced, usually if its been wedged and knifedged it'll be miles out and need a fair few lumps removing to bring it back, carl |
2nd Oct, 2008 at 10:28:52pm
The guy said he balanced it. Closest place for balancing in is Dubai. Maybe next time I am over there I will take the crank with me.
