Home > Technical Chat > Oil Pump Info
Tareq
Member #: 970
Bahrain
Hi again.. I searched everywhere but cant seem to find the info.
Would anybody have a clue about this oil pump.
Good for a high rpm engine or should I get something better?
Thanks again
its a steel backed pump and should be up to the job
if you want to spend a few sheckels more on a supaflow pump from Avonbar ... so be it
Tareq
Member #: 970
Bahrain
Thanks for that info.
You only get one chance to do this right, so spend money on a top quality pump, your engine will thank you for it *wink*
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Avonbar sell the powerflow steel backed one. Isn't the supaflow the ally backed version minispares used to sell?
On 19th Jan, 2010 wil_h said:
Tareq
Member #: 970
Bahrain
Bat.. for sure... thats why I'm asking questions.. Dont like to spend money and then it goes bang... Spend a little more and have some peace of mind.
Minispares "turbo" one is now the steel backed Powerflow one (much to Avonbar's dismay, I'm sure) - I have one on the bench, bought only a couple of weeks ago.
I guess even MiniSpares eventually respond to customer requirements :)
yes i ment to say powerflow gents
having said that matt wood (AKA... miniwilliams runs the standard steel backed one from minispares £11 with no bother and mats engines churns over 200bhp out he says he has had no issues with pressure etc... todate!
the choice is yours
Edited by BENROSS on 2nd Oct, 2008.
turbo hogster
Member #: 178
stowmaket suffolk
i also run the standard steel back pump, no probs and works well.
however if you run oil squirters then i would fit the larger capacity pump.
biggest killers of pumps is debris from the sump, eg swarf, most swarf will come from cams and followers if you run the 1.5 or 1.7 rockers and will kill even the best pump in know time.
since i swapped from 1.5 to 1.3 roller tip rockers my oil pump has last for years and every time i strip i ended given it a clean and refitted it.
how ever for my new engine she was graced with a new £14 one.
what ever you fit make sure it has a steel back as these will last alot longer than the alley back versions.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Fit a secondary magnetic pick-up in the oil pick-up pipe at the back of the gear box above the drive cup. The amount of crap that has stopped getting to my pump is scary!
Own the day
turbo hogster
Member #: 178
stowmaket suffolk
i have one but ended up cutting of the filter as i couldnt clean it out properly, but they realey need a longer magnet to be any good.
Those extra magnetic traps are dangerous to your engine, especialy the one without the strainer.
Crap builds up on the magnet to the point that there is enough there to either block the passage, or even slug a huge chunk of crap into the oil pump.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Mine works perfectly all the crap collects aroud the magnet and in no way obstructs the oil flow path. The fact it gets covered in debris proves its worth IMHO.
I clean mine in paraffin with the aid of an air line to shift the stubourn bits.
Why in gods name would you fit one that does not have a strainer!!!!!
Own the day
Simon@minispares.com
Member #: 1860
We have had these Powerflow pumps available since May 04!
