| Home > Help Needed / General Tech Chat > Headlights not working properly | |||||||
329 Posts Member #: 3193 Senior Member Torbay, Devon |
6th Oct, 2008 at 05:38:55pm
I have checked the wiring connections and they are all ok.
6th Oct, 2008 at 05:49:22pm
Blubs? Connectors along the slam panel? Fuse? Switch? In the 13's at last!.. Just |
6th Oct, 2008 at 05:55:08pm
what about that orange relay? mine was buggerd changed it and the light worked :) Drives
6th Oct, 2008 at 05:56:37pm
Try a new switch first. The headlights should not come on at the centre postion, unless you are just seeing the sidelights. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
928 Posts Member #: 65 Post Whore South Yorkshire |
6th Oct, 2008 at 07:26:45pm
The lights should operate independant of the ignition switch. Have you got a good earth on your new solenoid? I learnt recently (thanks Gavin :) ) that duff earths have a lot to answer for |
6th Oct, 2008 at 07:32:32pm
I'm with Paul, could be the switch has died, especially if you have fitted brighter lights/bulbs.
6th Oct, 2008 at 07:58:35pm
The earts are all o.k, have checked them all and everything else works fine its just the headlights.
7th Oct, 2008 at 01:18:57am
You did not answer the question on the lights coming on in the center position... so do they come on bright 1/2 bright or full??
7th Oct, 2008 at 10:56:53am
7th Oct, 2008 at 12:06:48pm
ANother quick update.
7th Oct, 2008 at 01:56:05pm
7th Oct, 2008 at 02:40:43pm
O.k!!
7th Oct, 2008 at 06:14:50pm
quickly whip the cowling off and check all onf the contacts and clean them up.
