| Home > General Chat > Whats the difference between................ | |||||||
17 Posts Member #: 3720 Member |
8th Oct, 2008 at 12:22:37pm
an 8v and 16v twinky cylinder head............ apart from double the valves!
8th Oct, 2008 at 12:31:26pm
Basically the 16v head will flow a little better and I believe the torque comes in a little higher up in the revs. The 8V heads can be made to fit a small bore block but the 16V im not soo sure? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
8th Oct, 2008 at 01:09:52pm
As it was explained to me and from my own observations the K head conversions give you a more driveable engine along with the horse power gain. and as said above the 8v delivers better torque low down in the rev range.
Edited by Mr Joshua on 8th Oct, 2008. Own the day
8th Oct, 2008 at 02:01:19pm
Thanks Guy's.
8th Oct, 2008 at 02:05:41pm
Hi
8th Oct, 2008 at 02:14:09pm
The basic difference is that the 16v will flow more than the 8v thereby there is slight gain in volumetric efficiency, particularly at high revs.
![]() 85 Posts Member #: 2234 Advanced Member Palm Beach Gardens, Florida |
8th Oct, 2008 at 02:49:13pm
Vizard got a patent on his PolyQuad idea. He uses one big, one small valve on the intakes, and ditto exhaust. So his 4V/cyl gets tumble and swirl, works like a 2V at low rpm. I like the idea and want to try it on a K head.
8th Oct, 2008 at 03:35:35pm
On 8th Oct, 2008 Paul S said:
I have a theory that the 8v would be better under very high boost because the 16v exhaust valves are too close together. I can't see that being a problem as the bike tuning companies run silly boost on the 16v's!
8th Oct, 2008 at 03:42:39pm
Yeh like 30psi upwards On 26th Oct, 2004 TurboDave16v said:
8th Oct, 2008 at 04:39:55pm
If the 16v has an achillies heel then my guess is that it will be exhaust valve seats.
13th Oct, 2008 at 12:44:17pm
Thanks for all your advice :)
13th Oct, 2008 at 01:06:59pm
Just right click on the photo, click properties then highlight the URL address. Add [i.m.g] before then [/i.m.g] after. But miss out the full stops in between the letters. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
13th Oct, 2008 at 04:50:26pm
On 8th Oct, 2008 Paul S said: The laziest modern bike engine I have rode was on the Triumph ST 1050 I think that reved out at about 9000rpm now if your engine is reving that high your doing well and as most bike engines hit 16000rpm I do not think resticted flow at high rpm is an issue we with our humble A-series motors have to worry ourselvs with.
The basic difference is that the 16v will flow more than the 8v thereby there is slight gain in volumetric efficiency, particularly at high revs. I have a theory that the 8v would be better under very high boost because the 16v exhaust valves are too close together. Own the day
13th Oct, 2008 at 08:42:02pm
On 13th Oct, 2008 matty said:
Just right click on the photo, click properties then highlight the URL address. Add [i.m.g] before then [/i.m.g] after. But miss out the full stops in between the letters. ![]() Well here goes then! |
13th Oct, 2008 at 08:43:27pm
Bugger |
14th Oct, 2008 at 11:31:07am
right click on pic, click on properties and copy and paste the properties text in.
